Home > My Defender > Corris 110.... |
That looks great did you just cut up the old dash centre for the switch holes? Ray
8th Oct 2015 6:22pm |
Excellent job, I've been thinking of doing something on a similar line for a while but im waiting for a centre piece that someone has already cut the top off for the double din mod. Ray
8th Oct 2015 7:24pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 578 |
That looks amazing. What do you mean by added some rads?
Also what did you cut it with? Are they all from the top line of buttons? Thanks |
8th Oct 2015 7:37pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2875 |
Originally I was just going to add 3 switches for the spots, but when I decided on the double din today I thought I would give it a go..I cut the three from the bottom and 3 from the top out with a 4" grinder but oversized. Then I used a belt sander to square and size them up. You then need to tidy up the back and make the thickness of the over hang pretty even. Then I rounded the corners and top edges by hand (added rads). They are just press fitted into the holes so no need for glue etc.A final clean and light spray of satin black and they look like finished parts.
8th Oct 2015 7:54pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Great job on the Mantec matey... Your skills and attention to detail on this truck are awesome, love the work you are doing sir... I am always envious of those that are capable of doing such great things with their P&J... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
8th Oct 2015 8:14pm |
Cheers buddy,
My last defender broke my heart, did so much to it but deep down I knew I should have started with a 110... Anyway onwards and upwards. |
8th Oct 2015 8:26pm |
Should be able to see ok when this all goes on!!
4 TS4000's Black for the rack Pair of Evo 2's Black Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
9th Oct 2015 7:47pm |
Some more work this afternoon,
Rear stainless strip. Click image to enlarge Fitted the Evo 2's and Wipac side and indicators. Will tackle the spots next. Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
10th Oct 2015 7:30pm |
TS 4000's mounted, wiring for another day....
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
11th Oct 2015 3:16pm |
Plan to get the double din and rear camera fitted over the weekend so made a start on the wiring. This is the switch arrangement I have gone for in the cubby. Bottom row is just rear fog, front rack lights, and then using a discovery top for either the rear camera or maybe a rear work light, not sure yet. Swapped the discovery switch head onto a heated seat latch switch and then just drilled a 3mm hole for the LED light when active.
Click image to enlarge Click image to enlarge Quite a load of wiring to extend but the carpets are pretty forgiving for hiding it so I just made up a loom and brought it through the gear sticks, can't be seen at all. Click image to enlarge All connected, lighting up and doing what they are meant to do... Much more room in the dash now as well to help with the HU fitting Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
14th Oct 2015 6:44pm |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 |
I like this alot! Very nice
14th Oct 2015 6:57pm |
Thanks,
Just need to trim out the inside off the cubby box now to protect the switches and job done...looks good in the dark. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
14th Oct 2015 7:02pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
Looks great, very impressed with your work! Keep up the thread really enjoying it.
14th Oct 2015 8:11pm |
That looks fantastic don't know if it's something you'd want as you've sorted the switch for the rear camera but I came across this from aus while looking for switches.
http://www.expeditioncentre.com.au/online-...variations There's a rear camera switch, rear work light switch, winch, and a few others. I realise the switch itself will probably be the same as you've used but the switch caps look very factory. Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Oct 2015 8:57pm |
