Home > Maintenance & Modifications > Whats the best headlight bulb upgrade |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2166 |
PIAA . Expensive but every time for me .
Click image to enlarge |
6th Oct 2015 8:33pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
I just purchased Osram Nightbreakers for my 90
(not yet fitted) but had read several posts on here regarding satisfying results Ebay, £10.00 posted for a pair G My confidence has been writing cheques that my abilities can't cash for years. |
6th Oct 2015 8:45pm |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
Go for Osram Night Breakers and Crystal headlamps, , the difference is amazing !!!!!!. More so if you do the headlight loom replacement .
6th Oct 2015 8:51pm |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
led headlights not bulbs
but i do use nightbreakers in my porsche |
6th Oct 2015 9:06pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3702 |
LED headlights is that a complete new unit?
Are the bulbs in a Defender H7's Thanks |
6th Oct 2015 9:09pm |
I bought H4 for mine
6th Oct 2015 9:30pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I did a write up for the conversion from standard to Wipac Cyrstals and Osram Nightbreakers here http://www.defender2.net/forum/topic24287.html?highlight=wipac
Coupled with a Red Bison Loom its the best upgrade you can do for your truck without spending a fortune on LED lights. Think my whole conversion cost less than £60 including the loom, lights, bulbs and a packet of biscuits. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
6th Oct 2015 10:30pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 711 |
Defenders are wired for h4 bulbs, and as above, osram night breakers and wipac crystal headlights are a huge improvement over standard, if you want to go further take a look at upgrading the wiring loom, again another big step up, but if you want proper brightness, and aren't worried about spending a few hundred on lights, go led.
The difference between standard and led, is literally like night and day! |
6th Oct 2015 10:32pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19698 |
Philips Extreme here.
6th Oct 2015 11:17pm |
stooby do Member Since: 14 Mar 2015 Location: St. Helens Posts: 68 |
As recommended a lot on here I recently went with the Wipac Crystal lamps, Osram Nightbreaker bulbs and the Red Bison boomslang loom, unbelievable improvement for the money.
9th Oct 2015 1:59pm |
Landy-Novice Member Since: 23 Jun 2013 Location: wiltshire Posts: 118 |
fitted on mine, crystal lights with 90/130w bulbs with boomslang loom and a 52" led light bar for good measure!
10th Oct 2015 6:37pm |
Hello
Has anyone a link for the uprated loom and clear lens, Is the loom a big job? sounds like it could be? Think for now it will be Osram nightbreakers unlimited, purely as I have a pair I never fitted to my wifes car and then we sold it... |
10th Oct 2015 6:59pm |
loom is almost plug and play, i extended my main pos and neg so both reach alternator.
loom: http://www.paddockspares.com/boomslang-per...-loom.html or here, exact same, alot cheaper(one i use) http://www.ebay.co.uk/itm/111466280732 clear headlights: http://www.ebay.co.uk/itm/RTC4615C-7-LAND-...4d2fc73f49 or if your a tart like me. clear halos. http://www.ebay.co.uk/itm/Angel-Eye-Headli...5d3ca16796 |
10th Oct 2015 7:06pm |
Just bear in mind. When swapping headlights that they'll likely need re-alignment especially for the MOT.
So I'd recommend taking if to one and asking for them to be aligned, it'd cost peanuts too. I only found this out come MOT time myself, luckily the tester just adjusted them and passed still FOC. |
10th Oct 2015 7:17pm |
