Home > Td5 > MOT failure |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
nothing wrong with either, take your pick.
The Monroe's may be gas shocks, worth the extra pennies Track rod end easy enough, as long as old one hasn't rusted into the drag link and seized ... Then It's a pain, but still not a disaster Guns and Landrovers .... anything else is irrelevant. |
21st Sep 2015 9:16pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16999 |
If it's failed on bushes, just fit new bushes! Rear damper bushes, especially lower bushes, seem to need renewing every 20k miles or so.
Drag link ball joint is normally an easy job. |
21st Sep 2015 9:40pm |
hily Member Since: 23 Sep 2015 Location: northumberland Posts: 15 |
As posted you can replace bushes only.One comment any play on steering ball joints should be a fail !
30th Sep 2015 7:28pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Took to local independent who fitted new bushes as shocks were ok. At same time he adjusted hand brake, replaced seal (oil leak) and provided me with replacement screw for one I lost on plastic cover that covers viscous fan and belt!
Passed MOT on retest |
30th Sep 2015 9:08pm |
