Home > Technical > How to Remove Front Grill |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
I pushed them out with something flat from behind. You have to be slow, steady and push squarely.
They will be reusable if your carefull and they haven't been out too many times. |
20th Sep 2015 7:43am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2015 |
It's easier to remove the grille panel if it's an air con model.
A screw on each side plus four at the top, then you can attack the little fir tree ! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
20th Sep 2015 10:01am |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
I took the grill off too! Much easier to get at the 'trees'...
What are you planning! YOLO... You Only Live Once... |
20th Sep 2015 12:29pm |
