Home > Td5 > TD5 error codes? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
I just bought a X431 iOS to check code of my TD5, play around a little bit, it shows up some thing like in the pic!
Is it serious problems? |
11th Sep 2015 5:10am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
The first 3 faults is a unexpected low and high value. That is normally not a problem. I have them regularly with my Disco 3.
A td5 doesn't have a Canbus so that should not give a fault except if the system is looking for a Canbus. Shuttle valve? I am not sure what that is on a Defender. Can you get the real faultcode number with your system? as you can google that number and get a better explanation maybe. Are you sure the X431 is TD5 compatible as a TD5 is not OBD II. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Sep 2015 5:58pm |
The only shuttle valve that I'm aware of on the Td5 is in the ABS/Traction Control modulator block, there's two switches in the bottom part of the block which power the valves.
Allthough many modern OBD2 readers can get "into" the Td5 system they may not necessarily communicate properly. |
11th Sep 2015 7:26pm |
Thanks everyone's input, x431 is compatible with TD5 , the shutter valve was a code from ABS!
12th Sep 2015 1:49am |
