Home > Td5 > First things to do on a TD5 Defender...
MGDM4
Hi all,
I just bought myself a 2004 TD5 Defender 90 Hard Top, which I am very pleased with. Very Happy It's my first Land Rover and first Defender.
Was just wandering what the are the first things one should do when they buy a Defender? (Service, under-seal, sound proofing etc etc)
Matt
Post #451979 3rd Sep 2015 9:39pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Hi Matt
Welcome aboard Thumbs Up
Can I politely suggest that you upgrade the OE security?
The search tab on here will be your friend..
TT "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #451984 3rd Sep 2015 9:48pm
Security, under seal, enjoy Thumbs Up
Post #451994 3rd Sep 2015 10:02pm
MGDM4
Thanks TooTall. What would you recommend? A pedal lock box, tracker, steering wheel lock?
Matt
Post #452003 3rd Sep 2015 10:11pm
grumpy old git
Check the oil pump bolt?
Post #452005 3rd Sep 2015 10:17pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Get it tuned, larger intercooler, remove the EGR valve, sort the gearing ratios to 1.2, make sure it's watertight, upgrade the front discs to vented if they aren't already, kony heavy track shocks all round, while your doing that I'd change the bushes for Super Pro's, Wipac crystal headlights with nightbreaker bulbs, TGE panels in the rear sides with some soundproofing behind, get it serviced by a good local independent - and then just enjoy it.
Post #452028 4th Sep 2015 5:05am
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Fill it up with fuel and use it , only fix it when it breaks Wink Have fun be happy
Post #452043 4th Sep 2015 7:47am
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
I've got a td5, had it 18 months now.
First thing I did was the security. Bought an Adrenalin pedal lock then got a Skytag tracker unit from Matt at FCX via the forum discount. Went down to FCX where he fitted it.
Ended up buying a new metal lockable cubby box from him! Another good buy.
Then get the underbody treated and sealed.
Enjoy
Andy Defender Td5 XS90
Post #452052 4th Sep 2015 8:13am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've used an Adrenalin lock for 3 or 4 years on the 90 and it's a great bit of kit. The downside however is that you have a large lump of metal loose in the back and are continuously walking around to stow it/fit it.
More recently I fitted an X-eng pedal lock to the 110 and whilst it is more expensive, it is a lot better. It takes a little time to install it perfectly but once in use it's great and has stood up well to being repeatedly kicked with muddy boots. Simply unlock, drop down and off you go. - I would definitely buy another one.
As said, Matt at FCX was doing a good deal on Skytags via the forum discount, we have had 3 units from him now and are very happy with the level of service.
Post #452123 4th Sep 2015 10:52am
Hufflepuff
Unfortunately the X-eng pedal box won't fit if you have the air con panel fitted on the Td5 Sad I've seen that pedal box and its absolutely superb - so easy to activate that there is no reason not to use it everytime you get out, but gggrrrr....
Post #452146 4th Sep 2015 12:17pm
JJ440
Switzerland 2001 Defender 90 Td5 SW Oslo Blue
Cosmetics aside... If you know the service history and it's up to date, I would just enjoy it.
Small problems will start surfacing as you start using it more. From windscreen wipers to the wiper park switch. If the master clutch cylinder hasn't been done recently, you'll probably be doing it.
If you don't need to do anything, then don't. You'll be at it soon enough.
Only thing I would advice you to check is if there's oil seeping out of the wiring loom into your fuse box (under your seat).
Ooh, and maybe bumperettes, within the first month of ownership I drove into a pole at the office parking garage, twice.
Post #452179 4th Sep 2015 1:41pm
roel
Take all the shine bits off and install old parts and some big tyres and have fun. Whistle
my 90 td5
By now all parts are painted the same color:
 Roel
2003 90 Td5 (2009-now)
Post #452337 4th Sep 2015 10:28pm
keith
Your neighbours must love you Rolling with laughter
Post #452339 4th Sep 2015 10:36pm
roel
I clean that up too. Laughing So I don't have any problems with my neigbours.
 Roel
Post #452341 4th Sep 2015 10:42pm
Little Tom
United Kingdom 2004 Defender 110 Td5 CSW Bonatti Grey
There is the whole if it aint broke don't fix it but I guarantee you something will be broke, you just don't know it yet! Laughing
My list was security (nothing major) then on to the faults, replaced injector harness, replaced rocker cover gasket and injector seals and washers, replaced FPR gasket. Then I painted it pink and stuck the fluffy dice in. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
Post #454960 14th Sep 2015 1:53pm
