Home > Puma (Tdci) > Parking sensor kit |
pcoote Member Since: 01 Aug 2010 Location: Oxford Posts: 83 |
Just wondering if anyone has fitted a gizmo parking sensor to their pride and joy. Obviously fitting a rear bumper step and waiting for the bump would do the job but I'm thinking of something more like this http://www.chameleondirect.co.uk/index.php...cts_id=319
12th Nov 2010 9:09am |
http://www.parkingsensors.co.uk/adhesive_p...udio_4.asp
No drill, no fear I have it and it works well Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Nov 2010 9:41am |
Here my work
Click image to enlarge Click image to enlarge Click image to enlarge quite invisible installation....... Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Nov 2010 9:05pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2285 |
Hey Dani
is the "beam" a cone or is it flat? thanks MK Puma 110" SW ............................................................. Earth first. Other planets later |
12th Nov 2010 9:51pm |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
Are the inner two sensors mounted to custom brackets? If so, where are they bolted to?
And to hijack the thread, a really stupid question (since I am going to be attempting to fit my NAS rear step this weekend): I understand the power connector for the towing electrics is behind the right hand rear speaker. Where do you run it out to the bumper?
2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
12th Nov 2010 10:40pm |
"elliptical" cone with the major axle parallel to the ground Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Nov 2010 11:58pm |
Hi James, I made two small brackets bolted to the two existent small brackets originally welded on the NAS rear step for the trailer connector. The "towing electrics power connector" is behind the black plastic cover INSIDE the rear right wheel arc/wing, after the fuel pipes. I taken the +12V and the ground from the rear reverse lamp. This twin cable and the sensor cables (4) pass through a 32mm dia hole (made by me) with appropriate grommet and convoluted tube. In this area (behind the right hand rear speaker) I put the ECU and the beeper also. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Nov 2010 12:14am |
Thanks!
Now all I have to do is to work out how to put the NAS rear step together (see my separate post!)
13th Nov 2010 1:10am |
Hey thanks D.
Excellent pics, hooking up to the reverse light so they fire up auto when reversing, nice. Having a Defender in Venice must be interesting, I couldn't see on your pics but I'm assuming you have a snorkel I took my TD5 all over Italy, including Sicily, got the 24hr ferry from Genoa. Parking in Palermo was always a worry but never had any problems. In Sicily I came back to my parked up wagon to see these guys standing round my car looking at it, but they just wanted to say 'Bella macchina' to me and shook my hand. The TD5 was stolen last year off my own drive, tsk. |
13th Nov 2010 10:59am |
a looooong snorkel.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Nov 2010 2:46pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I've also fitted these (although I only went with the two sensor version). Works brilliantly. Obviously I get erroneous readings with the sankey attached but otherwise wouldn't be without it when parking in the high street.
It took about 30 mins to fit. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
20th Nov 2010 12:46am |
