Home > Technical > What have I done wrong - stub axle
Page 2 of 2 <12
mikeh501
4 wheels! officially its a rolling chassis Mr. Green
and today, then engine is in! Very Happy
i hope the suspension compresses a bit. the top of the engine is 5ft off the ground lol.
Post #450913 31st Aug 2015 8:03pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
Wow! Bet it's never going to look that clean again! Lovely rebuild ... Thumbs Up That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #450924 31st Aug 2015 8:31pm
I see you've gone around the edges of the tank, what with?
Nice wheels, the best ever Mr. Green
The springs will sag, mine have dropped 60mm at the rear, over a period of 6 weeks, I loaded the rear tub up with 2 spare wheels, I put a minus 1" spring on mine, I measured the top of the tub before strip down on std springs, it was 80mm higher on new -1" springs Shocked Shocked
I might be putting standard springs back on, as I may opt for the NAS Spec cage and hood, instead of a truck cab, though no definite plans yet (until I find £2.5k!).
Looking good so far Cool
Post #450925 31st Aug 2015 8:32pm
mikeh501
thanks! yeah pretty chuffed its finally on its feet.
new tank from paddocks, painted with epoxy mastic 2 pack paint and finally stuck some dinitrol ML3125 around the middle Mr. Green should keep the rot out.
i did quite a bit of work on spring rates so im hoping its all going to come right Whistle
Post #450947 31st Aug 2015 9:51pm
I remember your initial post, when you got it on bidspotter...
What's the plan? Csw, rag, truck cab? Etc.
Post #450955 31st Aug 2015 10:20pm
mikeh501
Already have a rag top 200tdi. The body Is coming off that in one go and being transplanted on this. So kinda like a half rebuild. The top half started life as a hard top and I put a load of effort in last year to convert into a rag top. Give it another couple of years and I'll probably rebuild the body with a galv bulkhead to finish it off.
Post #450959 31st Aug 2015 10:38pm
Page 2 of 2 <12
