Home > Technical > What have I done wrong - stub axle |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10378 |
A v8, just like the one I'm currently doing...
Have you not got your original stub axle bolts? It seems that may be the problem?? Though there's nothing obvious I can see....and I replaced swivels on my 110 2 weeks ago (and fitted the steering stop tab on the front of the swivel today...I fitted them on the back on one side before !!!). There is the dust 'shim' that goes on the swivel housing, people tend to forget them.. |
29th Aug 2015 7:06pm |
I'm assuming it's a Richards Chassis, I see a bracket on the left, inside leg that I had to cut off, as I wouldn't have been able to fit my exhaust on....
It wasn't on my old one?? |
29th Aug 2015 7:11pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
yup v8. ordered a refurb lt230 with ATB and a R380L this week. dropped the auto plan
I didnt put the stub axle mud shield on, nor put the lock tab onto the swivel. I cant see either making the difference. I didnt have any original bolts, as the whole thing so far has been purchased new. My current vehicle is still on the road so havent pinched anything of it yet. |
29th Aug 2015 7:13pm |
its actually a marslands V8 NAS chassis. which bracket?
All new? That is costing a penny or two then ! Nice spec though, mine isn't as fancy.
The bracket is the one that you can see on the first photo, just above the hook of your engine crane... I'm not sure what it's for |
29th Aug 2015 7:23pm |
Pushing the boat out
I'm told that's the exhaust hanger. The easy fix to my problem is to get some shorter bolts.... Just worried that's not the answer lol! |
29th Aug 2015 7:29pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
Sure you have the correct cv joints and half shafts in there?
Try loosening then about 3 turns to see if that helps the issue Steve 02' 110 TD5 Double Cab Rebuild Thread |
29th Aug 2015 7:43pm |
I'm pretty sure undoing the bolts, especially those at left and right hand side of the stub axle will fix it. I see the same issue on the pass side where the bolts are in but without the stub..... Thinking on, it could be the pass side is causing the problem! I have the tie rod attached. One to chk to tomorrow!
29th Aug 2015 7:47pm |
Two things.
1 are you sure that the axel stand is not preventing further movement. 2 have you checked what movement you get with the steering linkage disconnected. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
29th Aug 2015 9:31pm |
I'll be trying both tomorrow. Don't think the axle stands are a problem but looking at the picture they are in the way. Wouldn't account for why it won't hit the radius arm but that could be #2.
29th Aug 2015 9:35pm |
Rich broom Member Since: 26 Jul 2015 Location: Tiverton Posts: 78 |
Is your cvjoint pulled through the hub enough and circlip on?
30th Aug 2015 8:08am |
And the winner is #2 The pass side swivel was restricting movement because the tie bar has not yet been setup. Removing the bar gave me full steering lock to lock. Thanks! I'll drop a piccy on later. It's very shiny! I haven't yet pulled the CV joints through fully. No circlip either yet or shims. Do you still need them with heavy duty drive members? |
30th Aug 2015 11:17am |
Glad it's sorted, looking forward to the pic.
You would need circlips, I'm sure. |
30th Aug 2015 12:16pm |
30th Aug 2015 1:31pm |
