Home > Technical > Which MIG welder
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Which MIG welder
Trawling the net a bit baffled by the range of welders. Looking for general purpose with a bit of sheet metal work mostly inside......anyone point me in the direction of something. £250 quid mark? Thanks
Post #448193 21st Aug 2015 11:03pm
I bought a Sealey Mig from Demon Tweeks' ebay store. A friend is a Sealey dealer and he was still more expensive than DT.
That's some good buying power!
http://www.demon-tweeks.co.uk/tools-worksh...ccessories
Post #448198 21st Aug 2015 11:08pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
This one...
BlueMig 150T Mig Welder at only £224.17 + VAT from The Welders Warehouse Ltd
http://www.thewelderswarehouse.com/Welding...-150T.html
Just bought one last week for welding up a new rear crossmember (1/3 chassis) and it worked a treat.
Technology has fairly moved on since I last bought a MIG Welder 25 years ago! Very easy to use and good quality as well.
Also was the LRM Best Buy (Sept 2015)
Best of luck
LRmud --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #448199 21st Aug 2015 11:09pm
I sold a Sealey Mig to a friend in the motor trade a few years back, it's had more than a fair share of use and it hasn't let him down once.
I would try and stretch to a benzyl/euro type torch .
Post #448200 21st Aug 2015 11:10pm
Triggerfinger
Sealey are reasonable little welders great for hobbyist but there is more to just the welder to consider ie....
you will want to have a larger bottle & regulator (not supplied at the time of purchase)
The small bottles last about 5 min welding and you will spend more time running up & down to buy refills
Bigger bottles are rented from boc & the likes so you need open an account and the bottle is rented but cheaper
in the long run.
Plus you will be wanting a better welding mask than the one supplied with your new mig
Now the cost is rising all the little things start to add up to a small fortune & not even welded anything yet.
Other things to consider is the duty cycle of the welder (basically how long before it over heats when your welding)
then you need to go for a cuppa to let it cool down before carry on.
Mig welding outside is trail & error as the wind blows the gas away & your welding looks pants gasless outside is
better but very splattery and the slag will need battered off. (no good for car bodywork just blows holes every where)
If your doing a lot of welding id be going for a second hand miller/murex /Lincoln but finding a decent second hand machine is a lottery unless you know where it came from. Cebora is the same machine as snap on!!
Have a look on the welding forum matey lots of good info & tips here................
http://www.mig-welding.co.uk/forum/
Cheers Kev
Post #449412 26th Aug 2015 2:53pm
rallysteve
Have a look at R-Tech welders. Great quality/value and UK made. They have very good warranties and repair services and very good reviews.
I have one of their Plasma cutters and I shall be replacing my Clarke 155TE with one of their welders when I wears out.
I have heard a lot of complaints about the quality of the components in the Sealey MIGs with them being rebadged Chinese made machines.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #449426 26th Aug 2015 3:47pm
Retroanaconda
I got lucky and found a second hand Murex machine cheap which just needed a new wire speed pot soldered in.
Was advised by a welding friend to buy based on weight - heavier the better! Wink
Post #449532 26th Aug 2015 9:36pm
