Home > Technical > Vibration? |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
When I am driving about 65 mph, a weird vibration starts that manifests itself in the gear levers visibly vibrating and the passenger seat doing a merry dance. Strangely, the steering wheel does not seem to vibrate much??? The vibration gets worse as I go faster, then stops when I drop below 65 or so.
If I put the car in neutral, the vibration is still there. And it remains if I go from 6th gear to 5th gear... I initially thought this must be an unbalanced wheel... but the accompanying noise (whirr/whirr/whirr) coming from the transmission bell housing makes me wonder if it that? Car is a new MY15 Defender with under 1000 miles! I am out of ideas? How about yours please! Cheers, Pete YOLO... You Only Live Once... |
15th Aug 2015 11:55am |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
If it wasn't so new I'd have said a UJ.
Warranty work surely? |
15th Aug 2015 1:05pm |
Unbalanced drive shaft?
I am going to get all 4 wheels balanced and see where this goes. They are the 5.5 X 16 inch steelies! So there should not be an issue there really... Not seen thus one before... hence the post... YOLO... You Only Live Once... |
15th Aug 2015 1:09pm |
I HATE the thought of bloody warranty work! In my experience, the average 20 year old JLR mechanic is as much use as a chocolate teapot! I would far sooner sort this myself rather than going down that path if it was avoidable... Not bothered in spending a few bucks myself sorting this! YOLO... You Only Live Once... |
15th Aug 2015 1:13pm |
I would go with , wheel balance , tyre out of shape , wheel out of shape
15th Aug 2015 4:06pm |
UPDATE!
Problem was that ALL 4 steel wheels were WAY out of balance... 65 - 85g per corner! This is a new car, straight from the factory Anyway, all re-balanced and smooth as silk now! Thanks for the suggestions! Pete YOLO... You Only Live Once... |
17th Aug 2015 1:21am |
