Home > Maintenance & Modifications > Should I +50mm lift or no?? |
LoveB Member Since: 15 Apr 2013 Location: Uk Posts: 38 |
more info plealse landy andy!!!! if I had as much flex as yours I'd be happy lol.
what size tyres are you running? |
16th Aug 2015 11:54pm |
Thanks Landy. If you go through life with your head in the sand....all people will see is an ar5e!!
17th Aug 2015 8:40am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
My 90 is lifted by about 70 mm. Without any other corrections. I have been looking into that as almost everybody says I need it but Do I?
My steering is still self centering maybe a little less strong as before, but for sure not a danger on the road. I have a true trac in the front axle and that helps for goinng straight too so maybe because of the True track I don't need to correct the caster. Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
17th Aug 2015 10:34am |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
What about anti-roll bars Andy? Are you running them front or back, and if not is the on-road handling still acceptable? |
17th Aug 2015 12:55pm |
Davie L Member Since: 04 Sep 2014 Location: Glasgow Posts: 95 |
Davie
17th Aug 2015 4:06pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
I ran my NAS 90 with the 2" OME lift for 12 years without changing the stock trailing arms. No issues with bushings or handling. However, it was easy to see by looking at the upper bushings that they were "pinched" more on the bottom and slightly open on top. (they were Genuine bushes, and lasted the 12 years no problem)
I have the same lift on my Td5 110, and will be doing the bushings this week. (I have only had the lift for 6 months, and the bushings were worn when I got the truck last year) I did spend some time looking, and have picked up cranked trailing arms for the rear. I know that it will give less "squeeze" on the bottom of the new bushing, when the suspension is in it's standard position, and also when it's dropped to the bottom of it's travel. To me, it is one of those situations of thinking "well, the trailing arm is coming off, I'm upgrading to poly, so why not upgrade the arm?" |
17th Aug 2015 5:59pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5430 |
I removed the ARB's, and the handling was still better than standard. This was mainly due to the OME sports dampers, as they are valved to open very slowly, giving good cornering, even with roof tent on. Think it would be different with lesser dampers on.
Andy |
17th Aug 2015 9:26pm |
Thanks Andy and CDN38. That gives me more confidence - I was going for the OME shocks myself.
17th Aug 2015 9:32pm |
Hvae spoken to gwyn lewis. I think it'll be the 1' (30mm) lift with the ome setup. has any one got pictures of theirs in action? 90/110 not fussed. just want to maybe excite myself.
he says with the 30mm I wont need the propshaft. and I think he said its about 11' downward travel |
19th Aug 2015 12:45am |
Thats what I had on mine (30mm). Although I had the extra HD springs on rear as carry a lot of kit.
This is a mates, with the same kit. It's strange when you have the kit, as it's just so smooth you don't know how much it's doing. Click image to enlarge |
19th Aug 2015 8:01am |
OK I've sent Gwyn an email asking what he recommends Can't wait, its going to be like Christmas!
Oddly though his website doesn't currently list springs. I hope he can source those too. |
20th Aug 2015 12:17pm |
Hmm I might have got a bit carried away with the shopping basket...
6th Sep 2015 10:08pm |
