Home > Puma (Tdci) > Slipping out of 1st Gear |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16917 |
Not a common problem, and unfortunately it is almost certainly a selector problem or other internal problem in the box.
30th Jul 2015 11:23pm |
TerryC Member Since: 30 Jul 2015 Location: Dorset Posts: 2 |
Many thanks Blackwolf. If it had been noted before it might have given me some idea of the work involved. So we won't know until we crack open the box…… Not the sort of mystery tour I was wanting, but presumably a reputable garage will make the necessary diagnosis and rectify. Thanks again
31st Jul 2015 10:37am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19624 |
Often or not they are sent to specialist by dealers I would imagine due to the fact the are so intricate and time consuming.
31st Jul 2015 10:45am |
It may be a relatively simple fault, such as a stuck or broken detent spring on the selector, but the complexity of a modern gearbox is such that most dealers and independents will simply change the whole gearbox (main box, not the whole gearbox/transfer box assembly, that is) for a reconditioned service exchange unit.
You could get in touch with Ashcroft Transmissions in Dunstable (Ashtrans on this forum) for advice. They are without doubt the leading independent experts on Landrover transmissions and I am sure will know if it is likely to be a simple or sinister fault. |
31st Jul 2015 11:09am |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Just to add Ashcrofts will be able to fix it no doubt too rather than want to just swap the whole thing. 110 Hardtop
31st Jul 2015 7:29pm |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
When does it jump out? Under power - or on overrun/engine braking?
31st Jul 2015 10:54pm |
