Home > Maintenance & Modifications > Sill chequer plate - are gaskets necessary? |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
custom ..... do you simply use silicone to fix your c plate....no screws or rivets .....how long has it lasted?
19th Jun 2015 2:34am |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
That is a good idea... Sikaflex would work well. What do you 'fill' the countersunk holes with mate... cut off bolt heads? YOLO... You Only Live Once... |
19th Jun 2015 4:13am |
Agree Sikaflex is a one way process. Better to use gasket and bead the chequerplate edge with Sikaflex if required. At least you will if required have a fair chance of being able to remove it later. If you go through life with your head in the sand....all people will see is an ar5e!!
19th Jun 2015 8:54am |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 804 |
I used this stuff
http://www.ebay.co.uk/itm/NEOPRENE-RUBBER-...1075827316 I would stick it onto the chequer plate rather than the body work (unlike Land Rover). I have taken mine off to be reannodised in black and sourced this before I started. It was an absolute pig to remove the old stuff from the sills. Land Rover stuck it on full width for the first and last 200mm or so, then just stuck on about a 25mm strip top and bottom, but I would presume this was cost saving and it makes more sense to me to just cover the full sill. 2002 110 td5 |
19th Jun 2015 9:26am |
