Home > Wheels & Tyres > 35" Tyres
Technic-al
35" Tyres
Looking to put 35's onto my defender. Question is, will I get away with fitting 35/12.5 tyres onto my existing 16 x 8 wheels?
Has anyone fitted them to 8" wheels or will I absolutely have to get 10" wheels?
Post #429742 9th Jun 2015 2:47pm
camelman
I ran 305/70/16 which are 33 x12 inches wide on 16x8s no bother so the width should be ok.
The only thing with 35's is you'll need a lift kit and possibly a better offset so probably ET0 or maybe even more negative
Post #429813 9th Jun 2015 8:29pm
jst
i have run 12.50s on 8" rims on an off roader. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #429826 9th Jun 2015 9:28pm
takoon
Norway
No problem, just be aware of when you letting air out for better traction on soft ground, the risk of rip the tyre off the rim is greater. This also depends of wich tyremake you choose ( sidewall stiffness). God luck Thumbs Up -99 Td5 90 CSW
-09 Jaguar xk4,2 Portfolio
Post #429873 10th Jun 2015 6:43am
