Home > In Car Electronics > Charging second battery in 90 (leisure 110ah) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7708 |
what you runs works well for me.
in fact most of my vehicle starter batteries are leisure batteries charging off the alternator at 14.2 volts. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
3rd Jun 2015 10:05pm |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 |
I've got two leisure batteries on my boat (90ah) which are both charged direct from the alternator.
They show 14+ volts when the engine is running and have lasted for years and years. They start the engine and run the domestic circuits. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
4th Jun 2015 5:33am |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
You could get a dc-dc battery charger like a ctek d250s dual.
4th Jun 2015 7:03am |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Thanks for the input. I was a tad worried that a constant 14+ volt charge rate would damage the battery but it seems not.
(Quote mikeh501 You could get a dc-dc battery charger like a ctek d250s dual.) This looks interesting but a bit expensive. My need for some new AT tyres and a full service takes precedence though. As long as my wife can look at all her soap progs on 12v she will be happy. |
4th Jun 2015 7:24am |
I ran a leisure battery along side a starter battery on split charger permamently in a 90 I had , and all seemed ok , (mounted inside battery box )
only thing that would concern me is having a battery inside cabin area charging is possible gassing when charging without being vented to outside air , as the gases are explosive |
4th Jun 2015 8:37am |
munch90: what size were the batteries? Can you fit a decent sized battery in with the standard Defender one?
4th Jun 2015 9:04am |
My plan on venting is to either put a small louvred plate on the outside of the van and vent through this from the battery box. The battery box would fit on the raised wheel arch shelf. Or put the battery box behind the driver side bulkhed and run a pipe through the bulk head into the existing battery bay under the drivers seat. The second would be favourite as there will be minimal observable altertion.
4th Jun 2015 9:08am |
4th Jun 2015 10:54am |
it was on a 200tdi 90 I had , starter battery was bigger than standard and think leisure was bit smaller , but made my own tray etc and sold it about 8yrs ago so cant remember exact details , but was a bit tight in the box |
4th Jun 2015 10:58am |
