Home > Maintenance & Modifications > B reg chassis
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
B reg chassis
Hi guys I'm looking for a little help I have a B reg 90 pickup 1 owner from new 200+ miles and I'm thinking of restoring to original should I fit a galv chassis or paint a steel one what would you do ?[/code]
Post #421879 7th May 2015 10:12pm
shaggydog
Depends on the condition of the chassis.
If its not in bad condition I would just paint it, if your stripping everything then might be worth shot blasting and galving the existing chassis.
If its shot then replace it with galv Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #421881 7th May 2015 10:21pm
StephenO
Do it right first time...galvy chassis Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #421885 7th May 2015 10:27pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I had a n/a B reg 90, the chassis needed a few bits of welding doing for the MOT but not too much, probably around £200 tops. That was only because it'd been stood for a couple of years
I suppose it depends on several things -
1. how long you intend to keep it? - not much point in spending £££'s if you're only going to keep it a year or so, you won't get back the cost of a new chassis
2. what's the rest of the vehicle and engine like? You don't want an immaculate chassis and everything bolted to it isn't going to last long or is problematic
3. what are you using it for? If it's just a hack to run around in then don't worry too much, just patch it up and enjoy it
Post #421902 7th May 2015 11:30pm
I'm just putting a galv chassis on my B reg 90. The chassis I'm taking off is in really good condition, the very front needs a tiny bit of welding that's very easy to do (where the bumper hides the ends) and it has had a recent rear crossmember on too, which hasn't been a perfect job.
It will certainly come up nice for an hour of welding and a few hours with a wire brush and a can of paint. It's a shame really, though I wanted something do over the winter months......I just didn't anticipate it rolling into summer too!!
Post #421926 8th May 2015 8:27am
need4speed
Another thing to consider is that, in places, they seem to rot from the inside-out...
On that basis, if the vehicle is a planned keeper, I would budget for a new galv chassis. Sorry if that's not what you want to hear. Crying or Very sad
Post #422034 8th May 2015 2:52pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
^^^^^^ what he said The Land Rover 90 - Many are called, few are chosen.
Post #422174 9th May 2015 10:01am
simonpuma90
Thanks for all your suggestions guy but what I was trying to say was if I buy a brand new chassis I'm thinking of getting one in bare steel not Galv and painting it to keep it more original
Post #425215 20th May 2015 9:56pm
Fatboy Slim
Wales
Why not paint a galv one Si?
Post #425219 20th May 2015 10:03pm
Galv, or galv and paint.
Post #425225 20th May 2015 10:06pm
need4speed
Galvanise and paint.
Even standard defenders are stolen at an alarming rate... Stick a bright, shiny, unpainted galvanised chassis on one and the scum will be attracted to it like magpies to jewellery.... Sad
Post #425261 21st May 2015 8:02am
