Home > Td5 > TD5 home service
Page 3 of 3 <123
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Top cover off, you'll see the filter under the exhaust manifold. It wasn't me!
Post #419243 26th Apr 2015 7:19pm
Screbble
Engine oil and filters sorted now.
The oil filter 'jiggling' was fun - I think my definition of jiggling is struggling like a man with ten thumbs!
All went ok though - not much mess thanks to the bag.
Managed to get my hands on some genuine Land Rover MTF 94 for a very modest cost so I'll have a crack at the gearbox this week, along with the transfer box (EP GL5) Any hints and tips before I take the plunge? Other than new drain plug washers, is there anything I should get hold of 'just in case' before I crack that nut. I've got the torx55!
All very therapeutic - with a hint of the placebo effect.
Thanks all.
Will.
Post #420617 2nd May 2015 11:52am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi Screbble
one tip is to buy a 5-7 litre hand pump sprayer (about £10) and use this to refill the gearbox\transfer box etc. Works a treat as you can position the flexible hose into the fill port.
Tommo
Post #420649 2nd May 2015 3:13pm
Screbble
Cheers Tommo.
Makes sense given the relatively poor access to the filler/level plug.
A 5l pressure sprayer ordered off Fleabay this afternoon - £7.50.
I bet it'll make filling both the gearbox and transfer box a doddle!
Thanks for the tip.
I'll keep you posted!
Will.
Post #420654 2nd May 2015 3:44pm
Screbble
That pressure sprayer really did make filling the gearbox a doddle - possibly even a pleasure......
Best £8 I've spent in a long time.
Feels like a new box, after filling with Land Rover MTF94.
Thanks for the advice/pointers.
Whilst I'm on, I can see the transfer box drain plug (1/2 square drive head), but can I heck find an obvious filler.
Any pointers, local landmarks for me to look for?!
Cheers,
Will
PS I know it'll be obvious when you tell me.
Post #422210 9th May 2015 12:53pm
JJ440
Switzerland 2001 Defender 90 Td5 SW Oslo Blue
Faces to the back of the vehicle, can be obscured by handbrake cable.
Post #422211 9th May 2015 1:00pm
grumpy old git
Easiest way I've found to remove / refit the transfer box filler is 3/8" drive to 1/2" converter with approx 100mm 3/8" wobble drive extension with a 3/8" breaker bar. They can be tight to undo!
Post #422243 9th May 2015 5:25pm
Screbble
Thanks guys. Job done.
It was obvious where the filler was when it was pointed out!
Both plugs were easy enough to remove and look relatively 'new' which appears to have been the case with the others.
Only managed to get a little over 2 litres of new oil into the transfer box despite leaving it to 'settle' for 1/2 hour. There must have been some residual oil in there even though I left it draining while I got on with something else.
I'll check it again next weekend after a few runs.
A std 1/2 inch short extension bar seemed to work ok (had the wobbly drive ready just in case).
I think the placebo effect has kicked in as it now drives like a dream....
....apart from the rattles....
....apart from the leaks....
.....apart from the noise.....
I wouldn't have it any other way. Always a big grin on my face when I'm driving it.
Thanks for your help and advice.
Will.
Post #422265 9th May 2015 8:35pm
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Hello, Is the the sump plug of the engine oil tank?
I went under the car today and found this...the under engine and gear box area is cover by a big sheet, mat be plastic!
I was able to spot this, and looks like leaking Mr. Green
Post #422370 10th May 2015 12:01pm
Page 3 of 3 <123
