Home > Puma (Tdci) > EGR tip |
On my 08 XS before I had the 'EGR off' option I never heard it once in about 4 years. Mind you SWMBO reckons I'm deaf anyway!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Mar 2015 3:05pm |
Forestman1 Member Since: 16 Apr 2015 Location: Sverige Posts: 13 |
Hello DEFENDER2.NET!!
DEFENDER 110 S, 2011, 67000 km. My EGR valve was replaced in February 2013 and yesterday I had the engine service lamp coming on with the found error codes as follows: P0404 Return of exhausts Component is hanging open P1103 Mass air flow sensor Malfunction (temporarely) P1102 Mass air flow sensor Malfunction (temporarely) (Motor is running normal.) I have the chucka chuca´s of course and those have been there since I bought the car three weeks ago. (The Defender´s mileage is now on 67000 km and I have drowed it for approx 2000 km.) I let the codes go off yesterday and for now the yellow lamp is not lit. Will try to make it come on again and see how long it takes. The former owner had the engine lamp going on sometimes but he says that when he was running a high rpm for a while it went off. He then thought it was a dirty particulate filter and did this several times during the last year. He was mainly driving in town but I use the Defender only on main roads now. With those codes; do I have to change the bloody EGR vent again? There is no warranty left and I think it is quite absurd to take that cost within such a short time after the replaceing in 2013. Off course I see in this thread that people have replaced it like that. Here in Sweden we have a good Forum but there are still not so many experiences of the EGR problem. Please help me with some support on this. |
16th Apr 2015 6:21pm |
There is no particulate filter on a 2.4. If you have the time or inclination remove your EGR and clean it using brake cleaner. If not just replace it.
The codes you are experiencing and the associated MIL lamp are codes that will automatically reset after a few driving cycles if the fault does not reoccur in that time. They may become more frequent as time goes by. Try the cleaning method it will not cost much but time. These images show how clogged they can become especially in the gear operating mechanism. I doubt drilling a small hole in the casing as the OP suggests would prevent this..... Click image to enlarge Click image to enlarge More information here: http://www.defender2.net/forum/topic2227.h...r+cleaning If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Apr 2015 6:49pm |
As I see, looking on my engine the EGR is placed far down and not so easy to reach from the top as on other cars.
What is the best strategy to take it off for cleaning? From underneath or by dismounting a lot of tubes and cables that are in the way? |
18th Apr 2015 3:03pm |
If you have wingtop chequerplate remove the bonnet, kneel on the wing or use a stepladder to access it over the top of the wing, be cafeful with your elbows and tools etc. the wingtops dent very easily. If you go through life with your head in the sand....all people will see is an ar5e!!
18th Apr 2015 3:39pm |
Ok,
If I manage to get it off, is there something to be done after replaceing. Any adjustments? Read somewhere that a new EGR needs to be tuned or something... |
18th Apr 2015 6:19pm |
No. Take it off clean it, refit. If you go through life with your head in the sand....all people will see is an ar5e!!
18th Apr 2015 7:17pm |
Dreadnought Member Since: 30 Apr 2015 Location: Podkarpacie region Posts: 10 |
I,m soon to be buying a 50,000 mile 2010 Defender with Puma 2.4 All other diesels I,ve owned that have had EGR I have blanked the EGR off and unplugged. I do appreciate that on more modern vehicles it will upset the management system if I do this. I do not need to worry about lights coming on, I just don't want it going into limp home? EGRs are IMHO useless items just there to appease the greenies....and I lived in a country where the MOT doesn't include emissions, which on my earlier EGR diesels have improved along with economy as soon as I blanked the EGR?
4th May 2015 11:13am |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Just unplug it, but the MIL light will come on at one point.
The fact it does that, you won't know if something real is going wrong, so that's why I haven't done it myself. Other option is to rewrite the ECU and close it that way. Third possible option is like this: I know a guy who is planning on experimenting with moving it into the air intake thus fooling the system. No further info yet if it worked or not though... |
4th May 2015 11:19am |
Thanks zone...with my other diesels I just made up a blanking plate, they were not as modern as this one being Renault, Rover and VW. Each and every one definitely benefited from having the EGR blanked off.
4th May 2015 2:28pm |
My EGR is still under (extended) warranty, so I haven't yet bothered. They replaced it once and the second now has a hole in it for lubrication (I know, still need to make the picture). If it fails again within the next commaing 18 months, it will be a new 3th one. If it fails later, I will have it written out as the cost is about the same as a new one + placement.
4th May 2015 2:55pm |
As mentioned with a 2.4 Puma unplugging the EGR valve and running with a permanent MIL light could potentially mask a more serious issue. The only effective and wise way of doing it would be partial blanking which proved to be successful in the earlier days of Puma ownership prior to EGR switch off remaps. I am unaware of any proven methods of simply blanking it off without having the associated MIL light. You started with the blank with the largest orifice and gradually reduced over time until the MIL light illuminated then went back to the previous size. Each vehicle was different so no definitive size for all could be said to work. It was trial and error until you found the size ideally suited to your needs.
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th May 2015 2:56pm |
Where can we buy these partial blanks?
I´m on for a new EGR now on warranty and maybe a partial blank would be wise to put in? Defender 110 SW S, 2011, Galway Green |
4th May 2015 3:01pm |
Same question came from an established Forum member in Germany. I sent him the set I have (minus the blank I still have fitted) and he had a set made and returned mine. If you have no success finding any and have a means of getting some made you pay the postage and return it when finished, I'll send you one of mine as a pattern. The smallest one had an 8mm hole and largest 19mm with a selection of sizes in between.
A small advantagious modification he made was to turn the two mounting holes into slots so the EGR bolts only had to be loosened rather than undone to swap the blanks out.
4th May 2015 3:07pm |
