Home > Maintenance & Modifications > Bonnet striker loose |
Hasnt the pointy end got a screwdriver slot and there is a lock nut inside the spring and the bonnet has a threaded insert in it
undo lock nut inside spring at the bonnet end of spring adjust with screwdriver in slot , tighten lock nut Sorry cant remember if they changed the design at all , but used to be like this (sometimes you need a narrow open ended spanner to get in on lock nut ) only other type i can think of is , there is a big hex at the bonnet end of spring thats the lock nut |
12th Apr 2015 9:00pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 843 |
That seems the right description, but I turns easily I'm guessing the captive nut inside the bonnett isn't captive anymore ?
13th Apr 2015 2:22pm |
Just screw the whole thing clockwise still it stops then adjust so it goes straight into the slam panel hole and then nip the lock nut up with a spanner. Ray
13th Apr 2015 2:51pm |
