Home > In Car Electronics > TDCI Style switch holder/sockets |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Hi guys,
Does anyone know if you can get TDCI style switch holders/sockets as a one off or bank of say 3? I'm trying to think how to mount some switches onto.....something but don't want to buy a centre dash and destroy it to get out a few small bits of plastic. I'm trying to avoid using carling switches because I just don't like the look of them Anyone know what I'm on about? Thanks in advance Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
28th Mar 2015 11:37pm |
Didnt fcx fit 3 switches in a cubby box that fitted in a puma style bezel with puma switches
or are you talking like a switch pod to take puma switches or something like this eBay Item No. 191541333371 Last edited by munch90 on 28th Mar 2015 11:46pm. Edited 1 time in total |
28th Mar 2015 11:41pm |
Thats the sort of thing
The switches seem to click into some sort of holder/housing/socket thing. I'm after that bit. Not to be confused with the likes of a mudpod or anything like that, its the thing that the actual switch goes into. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
28th Mar 2015 11:44pm |
Or something like this , doesnt it match your switches , ok you may need different ones
eBay Item No. 191541333371 |
28th Mar 2015 11:49pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
We use the parts from a genuine puma dash which is what Shaggy is trying to avoid and the minimum is three unfortunately. I did have a lead on individual holders, I'll chase it up and report back |
29th Mar 2015 8:58am |
Thanks Matt Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
29th Mar 2015 4:36pm |
Buckblu, killer is selling what you are after here
http://www.defender2.net/forum/topic35909.html Ray |
29th Mar 2015 6:52pm |
Hit the nail on the head there Buckblu
I'm trying to find a way of adding some genuine buttons in a way that looks well placed rather than the usual Carling switches for everything everywhere approach which seems to plague early defenders. Not even totally sure where to put them yet but once I have something to play with I'll have a better idea for placement as you can "offer it up" Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
29th Mar 2015 7:01pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 711 |
I've seen that, unfortunately i think its too wide for my cubby box, I have an early exmoor trim locking cubby, which is wider and has a shorter cup holder, thanks for the heads up though |
29th Mar 2015 7:20pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
A 6-switch carrier is fitted to the Discovery-2 -
Click image to enlarge Click image to enlarge Two of these carriers can be fitted into a DIN aperture - Click image to enlarge Click image to enlarge Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 29th Mar 2015 8:16pm. Edited 3 times in total |
29th Mar 2015 7:53pm |
That might just do the trick Paul
Does it take modern/td5 switches or only disco switches? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
29th Mar 2015 7:56pm |
The TD5/Puma switches are based on the D2 switches - in fact, the TD5 Defender's heated seat switches are the same ones, as fitted to pre-facelift D2s.
So, yes, the Defender switches will fit the D2 carrier. Depending on which Defender switches you use, you may have to remove the switch's body keyway, so that it will fit into any position - Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
29th Mar 2015 8:08pm |
Once again star Paul
Thanks guys will have a mooch and see what happens Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
29th Mar 2015 8:12pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 578 |
Been looking for something like this, great tip on the Disco item, £10 on the Bay at the moment, will get one to play around with. Feel better about cutting one of those up rather than a full defender panel.
30th Mar 2015 11:37pm |
