Home > Technical > DRL's
Juddy
Australia 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
DRL's
Day Time Running Lights
Where under the bonnet is the simplest place to take a ignition feed or similar for these lamps. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE
www.landybitz.com.au
Post #410483 24th Mar 2015 12:07pm
munch90
Why would you need a ignition feed for drl lights
if you use a drl controller then you only need perm + and earth
not sure of law where you are , but drl lights here have to dim or go out when you switch side lights on , if you run lights all the time at same brightness thats illegal here
Post #410607 24th Mar 2015 8:40pm
Juddy
I have no idea what a drl controller is, well i do now. Do these come with the lights or is it something you have to source alone?
Have to check the law here then... 2010 Defender 130 HCPU
Post #410620 24th Mar 2015 9:19pm
munch90
No you can get controller on there own , not expensive about £20 here
easy to wire
pos to battery , earth , wires to drl lights , wire to sidelight
ign on no lights
start engine lights come on
side light on , drl dims or goes out
switch off lights go off
there are lots of controllers available that do diffirent things , some dim , some drl goes off with sidelight etc
Post #410622 24th Mar 2015 9:25pm
Juddy
Ah all clear now, thanks for that did a google search, not many in AU, lots on eBay, placing a order with Amazon UK
So I think this one should do the job
http://www.amazon.co.uk/gp/product/B00FPF8...YN5AM2F3L3 2010 Defender 130 HCPU
Post #410656 24th Mar 2015 10:33pm
