Home > Wheels & Tyres > 16" Sawtooth Wheels: do they need spacial wheel nuts? |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Thinking of upgrading to 16" Sawtooth Wheels for my 2.4 Puma and read a post that some 18" Sawtooths needed special wheel nuts.
Do the 16" ones need spacial wheel nuts or can I uses my standard LR nuts I use on Boost and Zu wheels? If yes, is that why I see them advertised "with centre caps and wheel nuts" as a package? |
24th Mar 2015 4:56pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
It's probably because if you are replacing steel wheels, you'll need the alloy wheel nuts. Wheel nuts for steel wheels are different. Cheers Simon |
24th Mar 2015 8:12pm |
Yes I know about the difference between steel and alloy wheel nuts; its the Sawtooth question I am interested in.
Thanks, Don. |
24th Mar 2015 8:16pm |
Believe it was the 18" Sawtooths that had the issue but only with the locking variety.
http://www.defender2.net/forum/topic34099.html?highlight=nuts If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Mar 2015 8:20pm |
I understood your question, but you asked why they sold alloy wheels with nuts, and I guessed it may because if a purchaser was going from steel wheels they would also need new nuts () getting new wheels and no nuts would be like buyng a toy with batteries not included... Cheers Simon |
24th Mar 2015 8:40pm |
Batteries not included! Great film!
24th Mar 2015 9:12pm |
