Home > Tdi > Discovery LT77S ? |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
Yes it will fit but you will need to change the bell housing.
16th Mar 2015 8:20am |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Possibly the handbrake linkage
16th Mar 2015 10:49am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
It will fit but you will have to convert over the gear stick linkages as the Discovery's have a short stick and the Defenders have long sticks and the bellhousings are different.
To be honest I don't see any real benefit unless your old box is pre-Lt77 or badly warn? What do you have fitted currently? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
16th Mar 2015 1:55pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Hi shaggydog, yeah atm its fitted with the defender LT77 box, as reguards any benifit i was thinking gearing Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
16th Mar 2015 3:43pm |
Same gearing so no difference. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
16th Mar 2015 3:48pm |
What transfer box do you have?
16th Mar 2015 4:03pm |
Are right ok Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
16th Mar 2015 4:17pm |
There is no sticker or s/n on my tranny box but going off the way it drives i think its a 1.4 tranny box Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
16th Mar 2015 4:19pm |
If you changed the transfer box to a Discovery 1.2 box then you would get a slightly longer legged Tdi but would suffer when heavily loaded.
That said, this does seem to effect 110's more than 90's anyway so you should be ok being as yours is lighter to begin with Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
16th Mar 2015 4:29pm |
Ditto above, chap is going to do my one for me £150 fitted if my tfer box OK my box part ex
16th Mar 2015 4:32pm |
Be careful though as not all disco boxes have diff lock which would leave you with a serious disadvantage. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
16th Mar 2015 4:36pm |
Yeah something to look at once i have decided what i am doing with the engine Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
16th Mar 2015 4:37pm |
What you doing with the old one? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
16th Mar 2015 4:42pm |
That's a thought will check that!
16th Mar 2015 4:53pm |
