Home > Technical > Siren BBUS AMR4972 |
I think there sealed in resin
9th Mar 2015 7:33pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
Well that might have scuppered that idea then 2005 TD5 90 CSW XS
9th Mar 2015 7:36pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Just test it first?
9th Mar 2015 7:39pm |
Yes I agree, I was thinking of a year down the line, prudent to change the batteries while its at work but if no one has changed them before just bought new, I'll won't bother 2005 TD5 90 CSW XS
9th Mar 2015 7:42pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
I agree as its embarrassing when your horn goes off as your driving along........
It's mine I haven't just pinched it !! |
9th Mar 2015 7:51pm |
Does anyone know the current part number for the bbus?
9th Mar 2015 8:10pm |
Yep, I do
9th Mar 2015 8:14pm |
9th Mar 2015 8:19pm |
New from Dan @ Duckworths
LR014059 |
9th Mar 2015 8:20pm |
9th Mar 2015 8:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16915 |
The batteries are not replaceable. They can be removed (a popular way to disable the BBUS) but it is destructive.
9th Mar 2015 8:42pm |
Sorted then 2005 TD5 90 CSW XS
9th Mar 2015 9:17pm |
Apologies. It's a AMR 4971, I've plugged it in today but it just goes off on its own?
Questions Is it naff? Does this type not work on a 2005 TD5? Do I need to buy another kind? Have I wasted my money because I was being tightfisted buying one from Ebay and not from a dealer? Im guessing answer number 4's going to be popular Keith 2005 TD5 90 CSW XS |
21st Mar 2015 11:19am |
When you plug it in it will go off until the battery is charged which usually takes a couple of mins. After this has stopped leave it ten mins then disconnect the battery to see if it works and makes noise correctly, then reconnect battery and see if it stops sounding. I had one with the same part number but I'm guessing the battery was dead because it didn't sound when the battery was disconnected then went off for two mins when the battery was reconnected
Ray |
21st Mar 2015 1:39pm |
