Home > Maintenance & Modifications > Under Ride Bar fitting
Tonyrec
I have just bought an OEM Under ride bar (not arrived yet) and was wondering if it's as easy as it looks to fit or not.
Post #404617 5th Mar 2015 12:40am
rustandoil
I had no problems when I fitted mine, you should have it done in half an hour Thumbs Up
Post #404620 5th Mar 2015 3:24am
Tonyrec
Cheers, looking forward to doing it at the weekend. Thumbs Up
Post #404857 5th Mar 2015 11:32pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
What's an under ride bar ?
Post #404893 6th Mar 2015 8:34am
jimbob7
If you mean the Landrover steering "guard" bar below you need a spacer on the o/s or n/s,can't remember which,lol, bout £5 from lr,some peeps pack it out with a load of washers,good idea to wax oil the inside,or use spray/axle grease,I painted (rustoleum) and stuck some clear vinyl film to mine to protect it from stone chips anorl.I get the impression they wont last long without.
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pov.spec,ftw. 2006, 110,TD5.
Post #404981 6th Mar 2015 1:36pm
Tonyrec
That's exactly what it is.
It's secured with 4 bolts (3 of which are already on the vehicle). The 4th has the spacer etc and utilises a hole that's already there.
Our last 110 had this already on and whilst it doesn't offer the same strength as the large plates, I feel that its a bit more discrete and will do the job. It is something that can be specified on a new build from the factory for about £80.
Post #405193 6th Mar 2015 11:30pm
