Home > My Defender > What Did You Do In Your Defender Today |
It was like Christmas this morning, several boxes kept appearing at the door.
So took the steering wheel off, (thanks Bob) counted splines all 36 of them, fitted boss, tightened up the nut then noticed that there was a gap of 3/8" between boss and plastic cover round the column and I could see the steering column. Not being sure if this situation was correct rang Alive and explained the problem to Ben who was very helpful and thought that the boss should fit closer to the plastic just like the old steering wheel. So off comes new steering wheel and boss after a game of tug o war, out with trusty callipers and rule, appears from first inspection that boss is not going on far enough to the column. Old steering wheel back on and awaiting some engineers blue to find out how far it is going on the column and if the splines are fully engaged. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
3rd Mar 2015 9:22pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
If yours is a my2015 model they have changed the steering column plastic so there will be a GAP if the boss does not take acount of this!
4th Mar 2015 4:21am |
I wish, its a 2008 110 . Don't make old people mad.
4th Mar 2015 11:45am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
I don't normally go round bumping into things. unfortunately for the old couple I gather they have a lot going on in their heads - thankfully no one hurt and just a simple dent in the middle of their door - just a minor rub mark on my bumper end so it could have been much worse. |
4th Mar 2015 12:05pm |
hamtheman Member Since: 19 Mar 2013 Location: Louth Posts: 35 |
Not today - but recently picked up this guy in my 90. Great addition!
http://mylandy90.blogspot.ie/ |
5th Mar 2015 3:43pm |
^^Gorgeous dog! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
5th Mar 2015 7:22pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
^^^+10 Very Cute! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
5th Mar 2015 8:57pm |
Very Click image to enlarge |
6th Mar 2015 11:45am |
Thanks a mill guys! Here's another one Click image to enlarge http://mylandy90.blogspot.ie/ |
6th Mar 2015 12:07pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Got asked by someone in work if I had a V6 under the bonnet of the 110....Nope its just a TD5 with no centre box 1999 Defender TD5 110
6th Mar 2015 1:07pm |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Bet it sound nice.
I had my 90 on the two post lift changing the rear shock mount, I thought let's see if the chassis got through the winter OK! Nope found a hole. Why did I look? |
6th Mar 2015 5:13pm |
Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 255 |
Changed back to summer tyres on both 110 and RR.
7th Mar 2015 6:09pm |
Excossack, my boy was feeling a little smug when I picked him up from school on Friday, it turned out that a couple of his schoolmates and a teacher were trying to work out what was under the bonnet of mine when they heard it pull away that morning. They wouldn't believe my boy that it's just the Td5, allbeit with a stage 1 tune, de-cat pipe and centre box removed, they were convinced I had a big V8 in it
7th Mar 2015 6:46pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Fitted a D44 Transmission Guard (took loads of photos so doing a write up shortly), not as easy as it looks.
Click image to enlarge Click image to enlarge Then I fitted some Glyn Lewis Front Outrigger Mud Protectors, I've got the back ones too, but ran out of time. Click image to enlarge Click image to enlarge Then it was a clean before getting it dirty again tomorrow Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
7th Mar 2015 7:41pm |
