![]() | Home > Maintenance & Modifications > Soundproof/Insulate quick advice? |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 ![]() ![]() ![]() |
Most of us use a combination of NoiceKiller, Dynamat & Carpet.
On the rear tub, I have NK under the carpet. Behind all the side panels I have Dynamat. Not done anything behind the roof lining yet. I have TGE panels as well because mine's a USW Very happy with the result. Can have a normal conversation at 65mph ![]() ![]() Click image to enlarge Also a Nakatenanga loadspace mat to keep the carpet clean Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 ![]() ![]() |
You don't 'need' to cover everything, but we do.
We use 'Dynamat' or 'Skinz' dependant on the clients preference / budget (I personally can't tell the difference when driving in a vehicle between them) - These are a foil sheet with a 'bitumen' type black sticky backing, it is this that is applied to the bare metal (be sure to degrease the metal first) We then apply a layer of 6mm neoprene, again from either manufacturer to all floor areas and rear seatbox / barrel sides / van sides (which we then carpet) [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] The lines in the carpet is our valeter being arty ! :roll: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 614 ![]() ![]() ![]() |
Blimey. Is that leather trim in the hard top back?
Of course !
