Home > Technical > Puma AS 10 |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
The alarm unit will also need to be coded to the engine ECU or the vehicle will not start.
What version of the 10AS are you fitting as a replacement, the ones with the black housing have problems being programmed by third party diagnostic tools (strangely, the green ones have problems being programmed by the official diagnostic software - L/R's SDD) |
11th Feb 2015 5:54pm |
tcqf Member Since: 27 Jan 2013 Location: devon Posts: 11 |
Thanks for help, I ve got the green one,tried everything to get it to start ,relays battery starter AA,ordered a nanocom to try to sort the immobilizer,I ve got an 08 110 utility ,had the problem when still in warranty just had to keep locking and unlocking the doors then it would start,LR said they could find nothing wrong with it and I should nt leave the doors open to long with the keys in the ignition???cheers
11th Feb 2015 10:24pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
I have had a few duff ones from breakers over the years i think its from them pulling them out with the battery still connected.
11th Feb 2015 11:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16923 |
There are known issues with the passive immobiliser if the keys are left in the ignition, or if two sets of keys are in range of the exciter coil in the column. Try turning off the passive immobiliser with your Nanocom to see if it helps. The vehicle is still immobilised when locked with PI turned off.
11th Feb 2015 11:33pm |
Thanks everyone for your advice all very help full!
13th Feb 2015 9:09pm |
All sorted I got a nanocom and turned off the passive alarm,started first time hopefully problem sorted
23rd Feb 2015 9:20pm |
