Home > Maintenance & Modifications > Difflock drain plug |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Great idea...too late for me tho
Name and shame so we can avoid Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
2nd Feb 2015 3:52pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5085 |
Clwyd |
2nd Feb 2015 5:16pm |
Just arrived from Femco UK http://www.drainplug.co.uk/
Click image to enlarge Awesome service, only placed the order yesterday Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
3rd Feb 2015 3:36pm |
If only all companies were so prompt with delivery. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
3rd Feb 2015 3:38pm |
Yes- came with a 24-hour courier...and they only charged £2.50 carriage Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
3rd Feb 2015 3:41pm |
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 |
Does anyone know which plug and size would be needed for a 2013 2.2 Puma?
Thanks in advance |
3rd Feb 2015 3:47pm |
Kitoper
On the Femco UK website ( http://www.drainplug.co.uk/ ) - there's a enquiries form (in "enquiries") - they'll spec-up the kit you need I think you need the same as me (TDCi's are all the same drain plug)? At least then if it's wrong, they'll be duty-bound to replace it Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
3rd Feb 2015 4:56pm |
Thank you Martin - I will share what I find
3rd Feb 2015 5:14pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1833 |
Ooooh, this is an old thread!
But... I've just changed the sump on my 300tdi. The old sump had a drain plug on it, like this: It's been on the car for at least the 17 years that I've had it, possibly the whole 24 years the car's been around, and given no trouble, so I was going to refit it. Unfortunately the hole on the new sump is a larger diameter (15mm spanner) so it won't fit. I had to resort to the standard plug to get going again. I could get another valve like that. I think they are about £25 or I could go for one of the femco/difflock ones. On the face of it, the femco one seems more robust/less likely to get knocked if off-road. But this one is so easy to use - just slide on a short length of hose; turn the tap; watch the oil drain into the container. Very controllable. Anyone used both and able to give any either/or experience? With the femco/difflock ones, is it the screwing in of the hose that opens the tap? Thanks Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
3rd Jan 2019 7:53pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5754 |
Correct - If you really want I can wander to the shed and take a pic of the brass hose end (the bit you see in MartinK's post) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
3rd Jan 2019 8:29pm |
Thanks for that - no need to get out the camera! I also searched for 'Stahlbus' ones, similar to the femco ones, and they had a diagram showing how it worked.
Despite the fact that I've had no problems with the femoto one for so many years, the femco/difflock one does seem more robust. Still interested in anyone's long term experience of them. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
3rd Jan 2019 8:45pm |
Mine has been in for 8 years or so. No issues and makes changing oil much easier. Ideal if you accidentally add too much oil and need to drain some off. 1999 Defender TD5 110
3rd Jan 2019 8:58pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
I have had one on my 2004 300TDi since the first (1000 mile) service, never had a moments problem with it.
Fitted one to my wife's Freelander 1 TD4 about 8-years ago, that also has been faultless. Both used twice yearly. ONE LIFE, GET IT! |
3rd Jan 2019 9:33pm |
I guess that will do it for me then. I'll get one ordered and fit it at the next oil change.
Thanks both. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
3rd Jan 2019 9:53pm |
