Home > Puma (Tdci) > Puma heater control adjustment |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Just for once, they are right, they do all do that
1st Feb 2015 12:10pm |
redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137 |
Unfortunately this is also my experience. It's also nigh on impossible for find that 'Warm' biting point...
Climate control it aint... Defender Puma 2.2 XS 90 Vespa GTS 300 Way too many racing bikes. |
1st Feb 2015 12:59pm |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 |
Fair enough!
Thanks chaps. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
1st Feb 2015 1:58pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16969 |
It's a normal characteristic, as are the wild fluctuations in temperature according to what the engine has been doing.
1st Feb 2015 3:57pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
I'd agree with the others on this, hot range for around 80% then a small area where it goes between hot, warm and warmish, then cold. I'm happy with this because previous Land Rovers never had the hot bit. I started with nothing and still have most of it left! |
1st Feb 2015 4:20pm |
Yes that's true. My TD5 struggled to heat up but I assumed this was an adjustment problem but apparently not. 2003 Td5 110 Hardtop
1st Feb 2015 4:28pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Five clicks from cold is about right, maybe one either way depending on how hard you're driving.
1st Feb 2015 7:59pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2012 |
Perhaps fitting a MUD heater deflector might help by deflecting the heat away from your leg and the handbrake ?
1st Feb 2015 8:18pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
I think you Puma owners are just out to pee us Td5 owners off with your "my heaters too hot thread" 2005 Td5 90 XS
Steve |
1st Feb 2015 8:21pm |
Is there anything that can be done about it? Mine does it too and it's really annoying.
It's like Land Rover decided that too many people were complaining the heater was too cold so they'd just make it too hot all the time. |
1st Feb 2015 8:43pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Don't know if the Transit has the same heater valve but not only does my Puma do it but my Transit based Motorhome does a similar thing. Not had a look to see if the MH has the same valve
Guess the only fix is to change the heater valve to either another manufacturers or if there is a 3rd party aftermarket one. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
1st Feb 2015 10:15pm |
You really want some kind of thermostatic valve, and I don't know of one. A big part of the problem is that the engine temperature fluctuates considerably when running.
You will also usually find the air discharged into the LH footwell is a lot hotter than that in the RH since the heater matrix is always several degrees hotter on the inlet/outet side (the left). There is a completely ineffective LR bodge -sorry, solution - for this, which really isn't worth the considerable effort required to apply! It is one of the many quirks that makes Defender ownership special and unforgettable, and every journey an adventure. |
1st Feb 2015 11:18pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1878 |
My last transit with the 2.4 had no issues with the heater, it worked great! My puma on the other hand is just like the rest a fine line between hot and cold
Could a climate system be retrofitted like the disco two? 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
1st Feb 2015 11:24pm |
charlesteton Member Since: 24 Feb 2013 Location: London Posts: 40 |
100% correct... Series=freezing, no heat. Don't know which I prefer!
2nd Feb 2015 11:18am |
