Home > Puma (Tdci) > central locking motor
bear100
It looks like my locking motor on the rear drivers side if cooked Evil or Very Mad are they serviceable?
only had a quick look on ebay and they are going for £120!!! Thud
I've greased everything and nothing is seized
anyone else had issues?
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #394401 31st Jan 2015 2:28pm
munch90
have you checked the wiring between body and door in the rubber joining tube ?
Post #394405 31st Jan 2015 2:40pm
K9F
You could perhaps get a multimeter and with the door open and door card off check the supply when selecting it to lock. Are these 'handed.' If not and it's not too much mither swap the rear two over and see if the fault transfers perhaps?
Pink and Orange (two seperate single coloured cables) are your lock/unlock motor inputs. Thumbs Up
As Munch stated the gaitored umbilical cables is a known vulnerable weakspot. A gentle tug of each cable where it exits the gaitor normally reveals the culprit. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394406 31st Jan 2015 2:42pm
bear100
Idea i will have to give that a try, i couldn't read anything on my multimeter it moves to quick!!
i did however have continuity across the two cables to earth, when central locking activated the continuity paused for a second so i am pretty sure the cables are intact Big Cry 2016 Range Rover Autobiography 4.4 TDV8
Post #394427 31st Jan 2015 4:12pm
munch90
I would check them visually not just by meter
Post #394440 31st Jan 2015 4:57pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I have a good spare motor bit sold vehicle now so yours for 60 posted 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #394467 31st Jan 2015 6:19pm
K9F
Check the cables first..... Thumbs Up
As mentioned the pink and orange cables there is an excellent photo of the common issue in the simultaneous thread running below.
http://www.defender2.net/forum/topic34609.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394475 31st Jan 2015 6:32pm
bear100
Cheers lads, I will check the wires in the morning, Thumbs Up
Pj if the wires are good I will gave that motor off you Thumbs Up
Mr. Green 2016 Range Rover Autobiography 4.4 TDV8
Post #394514 31st Jan 2015 7:51pm
pj2106
That's the reason I have it brought a new motor and then found wires broke but couldn't be botheredt I take new motor out lol 2008 110 2.4 XS Utility (Hagrid)
Post #394535 31st Jan 2015 8:37pm
bear100
Fair play guys you were spot on Razz
There was a broken wire in the rubber conduit, the cable Land Rover have used is not the best for the job it was very brittle Shocked
Replaced the faulty section and harmony has been restored Very Happy
Thanks lads Thumbs Up Thumbs Up
Sorry pj Rolling Eyes lol 2016 Range Rover Autobiography 4.4 TDV8
Post #394728 1st Feb 2015 10:56am
K9F
Good news and a satisfactory result. Well done. Bow down Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #394729 1st Feb 2015 10:58am
