Home > Technical > Defender Hand Throttle for utility applications
Page 1 of 3 123>
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Hi Guys,
Has anyone seen fitted Hand Throttle for utility applications ie Hydraulic Pumps etc.
In distant past i have worked on 130 Cherry Pickers but cannot remember if a governor was fitted..
Thanks
Andy Working towards Carry on camping!
Post #391368 22nd Jan 2015 11:02am
Which engine have you in mind?
I believe that factory fitted hand throttle options exist for both Td5 and TDCi engines, but I have never actually seen one and I am not aware of any aftermarket options. I am told that the factory option is blisteringly expensive - over £1200 for a TDCi.
If anyone knows more I too would be interested to hear of it. Logic suggests that in the era of modern programmable ECUs it should be a very simple task, and I have always been a bit surprised that there's nothing available.
Post #391377 22nd Jan 2015 11:19am
For a lot of American 4x4's (Jeep etc), you can buy an OBD plug in module that increases the idle to whatever RPM for winching. I read a winching report and they named the make of it... I'll try to dig it out.
Would have thought it would be something that IRB/BAS could make a killing on. Td5's as well.
Edit: Here's the unit... ProCal...<-----
And for those interested in winches, an interesting back to back winch test of the popular makes and models, where I saw the ProCal device mentioned
Post #391397 22nd Jan 2015 12:31pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I'm sure something could be rigged up using a choke control cable to move the throttle pedal to increase the revs in these instances there's even a hole in the steering column cowling for such a thing (left over from the days when you could buy a Defender with a petrol engine). 2005 Td5 90 XS
Steve
Post #391401 22nd Jan 2015 12:39pm
Navaras have a "fast idle" switch on the dash, ostensibly to speed warm up. The fast idle is automatically disengaged when a gear is selected.
It is a very simple system (at least if designed into the vehicle) and I have always felt it is a shame that Defenders don't have something similar.
Thanks for the ProCal link, I will read that, it looks interesting. Thumbs Up
Post #391413 22nd Jan 2015 12:54pm
uncas
For vehicles with fly by wire throttles you can't use a mechanical aid such as a cable. Phil Butler at Motor on services may have something for a Landrover but it wont be cheap,
Jeep owners used to use a thumb shifter for a mountain bike gear changer on the throttle to control the revs when off road. Some Toyotas had a hand throttle as standard to lift the idle speed at least my LJ70 did
Uncas
Post #391414 22nd Jan 2015 12:55pm
I've often thought about having a plug & socket off of a throttle pedal (Td5), and taking measurements of the resistance of the standard pedal when you're *just* pressing it down, so maybe 1000/1200rpm.
Get the socket, and the appropriate resistors to simulate the pedal at that desired position, and plug it in... wonder if it would work?
Post #391418 22nd Jan 2015 1:01pm
landy andy
There is a box of tricks that is sometimes listed on the forums ebay, for this purpose, normally removed from electricity board or similar vehicle.
Andy
Post #391421 22nd Jan 2015 1:07pm
See also this thread.
It seems a TD5 hand throttle could only be ordered on a new vehicle and in 2011 cost £1160.92 + VAT. Shocked
Post #391448 22nd Jan 2015 1:47pm
excossack
Could you use a choke lever and cable from an earlier V8 and then attach the cable to the underside of the pedal so when pull the choke the pedal goes down? When in the normal position, the cable under the pedal will slack? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #391457 22nd Jan 2015 2:09pm
110MGD
2001 Defender 90 Td5 CSW Epsom Green
Though not directly linked, sure I once saw a 110 Hi-Cap Td5, with a hand starter, like on a lawn mower, on the front wing.
The video was on YouTube. 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #391477 22nd Jan 2015 3:33pm
Cupboard
the problem with just putting a replacement foot on the pedal as I see it is there's no governing at all, so if you load it up the revs will just drop. That might not be a problem, but if you're wanting a particular RPM for a generator it might be.
I don't know how governed the Puma Idle Jack is, but I'd had an idea in my head about making a fast idle button that just told the ECU you were in first low.
Post #391495 22nd Jan 2015 5:22pm
Not that simple, I'm afraid, I've already thought along those lines. You'd have to tell the ECU that:
A) You were in the appropriate gear,
B) the clutch was in, and possibly even
C) the vehicle was moving, since movement or lack thereof seems to affect the IJ.
If you could do this it would work quite well since on tickover, with or without Idle Jack, the engine is effectively governed by the anti-stall.
The biggest problem with all this seems to be that the vehicle doesn't actually have any way of knowing what gear it is in except by the ECU detecting movement and cleverly figuring it out. For example, if you are stationary on a hill, in low box, in neutral on the main box, and the clutch is in, idle jack is not doing anything. If you release the brake and let the vehicle start to roll, then the tickover will increase as the movement is detected, if I recall correctly. So any effective aftermarket (or even factory) hand throttle really needs integrating properly into the control system.
Post #391510 22nd Jan 2015 6:40pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Tbh on a TDCI all you would need is another throttle pedal even a td5 come to think of it
With another set of wires into the original run to where you want it and just modify the pedal to be a handle simples not hard at all
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #391553 22nd Jan 2015 9:12pm
uncas
Big Steve I don't think that it's as simple as that if it was you could couple up a cable to the existing throttle pedal.
Uncas
Post #391596 22nd Jan 2015 10:24pm
Page 1 of 3 123>
