Home > Technical > Frozen Locks |
SS90 Member Since: 16 Nov 2013 Location: Uk Posts: 372 |
Would Glycerine be any good?
20th Jan 2015 12:38am |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 |
How about acf50 or a graphite lock lubricant?
20th Jan 2015 12:57am |
OldhamLandy Member Since: 17 Oct 2013 Location: somewhere Posts: 164 |
Silicone spray works for me - suffered on a few occasions previously with the early morning acrobatics due to frozen locks thus tried the silicone spray applied to the locking mechanism and door rubbers and voila, door locks work perfectly even in a harsh frost 2016 Defender 90xs SW - Santorini Black with Silver Pack
2014 Defender 90xs SW - Corris Grey with Santorini Black Roof |
20th Jan 2015 1:05am |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
I had a similar experience 4-weeks ago when I was home (now back in the tropics mid thirties and 100% humidity, it doesnt seem possible!).
I had the door cards off last summer and lubricated the mechanisms with white lithium grease. From what I gleaned after my episode, this solidifies as you get down to freezing temperatures and the central locking solenoid does not have the required power to overcome the extra resistance, so it simply never unlocks the door. I believe it is the drivers door solenoid which is the master, so this is the main problem. When I am next home, at the summer, I intend to open everything back up again, clean everything off, and spray with ACF50 |
20th Jan 2015 6:22am |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
Did mine as above last year. Worked then and still okay. |
20th Jan 2015 7:57am |
Push the blade of your key into a tube of silicon grease and then into the lock and turn a few times... No more problems. Do the same with the fuel tank cap key/lock.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
20th Jan 2015 8:04am |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 311 |
Nitro Glycerine? Sandy |
20th Jan 2015 8:05am |
think that's what my van door just needed , some Nitro Glycerine to get it open
20th Jan 2015 8:12am |
Sandy
20th Jan 2015 8:23am |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 666 |
Silicone spray for seals and ACF50 for the locks
21st Jan 2015 9:52pm |
The Hi-Tech solution: Heated Door Locks...
(Website in dutch - try Google Translate) Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
21st Jan 2015 10:29pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Had to open the car several times this morning, it kept closing itself back a few times. Then suddenly it worked.
Probably something that was frozen stuck (push button maybe) making the system think it needed to close up again. |
22nd Jan 2015 8:49am |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
? Just poor warm water over the windscreen untill all the ice has gone, I do this to frozen door rubbers too, I've done it to all my cars over 30 years and never cracked a screen?
Disclaimer don't copy ME . 2005 TD5 90 CSW XS |
22nd Jan 2015 7:20pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Interesting mix of solutions offered - thanks.
Having previously 'puffed' dry graphite powder into the locks - I'm not too keen on using AC50 as well (after all it's a bit like WD40 - not really recommended for locks). Ericvv's suggestion of silicon grease appeals on the grounds that it is already used in some applications of locks. However that would suit the inner part of the barrel - it's the outer length of the barrel that appears to freeze, plus the mechanism - so I may end up removing the door card and investigating the innards for lubrication and anti-moisture treatment. |
22nd Jan 2015 9:27pm |
