Home > Maintenance & Modifications > Automotive Electrician Required For Lots Of Mods Install! |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Also try AES Auto Electrical Supplies for parts (wiring and connectors)
http://www.autoelectricsupplies.co.uk/mobile/ I ended up buying my Anderson connectors and made my own jump leads and got the parts from Totberry connectors http://www.torberry.co.uk Just remember if you fit and Anderson connector externally you need to have an isolator switch so your not constantly sending power to and external location where it may get wet Russell 2011MY 110 XS USW Black |
29th Dec 2014 1:08am |
you go link he gave you , then downloads and there is a wiring diagram pdf thing they ok to charge second battery , but wont link batterys for starting can just use a standard heavy duty relay , like a glowplug relay and just switch it by ign feed so battery charges when ign on , ok it links all the time ign is on engine running or not , the towsure is a voltage sensing so links when alternator is charging so bit better in that way |
29th Dec 2014 5:16pm |
