Home > Maintenance & Modifications > SoS - seat bolt sheared
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Hey. So trying to fit my flat dog dog guard and ive fallen at the first hurdle. It tells you to undo the bolts next to the second row seat bolt anchor bolts in the floor, 13mm jobs. But one of them has sheared clean off. I can't get the bottom half off it appears to go in to a bracket on the chassis? Is this structural? Can I drive it in this state?
Post #381608 24th Dec 2014 4:47pm
Northernremedy
Hopefully there's a photo attached. It's the single bolt which you can just see with the washer at the top it is next to the seat belt anchor point (just to the left as you look at this pic). Beneath it goes in to a bracket which attaches to the inside of the main chassis.
[/img]
Post #381619 24th Dec 2014 5:14pm
ickle
I think thats a body mounting bolt, depends on how far / fast you're intending to go, if you've got rear seat passengers and what you intend to hit!
So in theory no don't drive, in practice I would although I would think twice about rear seat passengers.
M8 tap from Santa?
Keith
Post #381620 24th Dec 2014 5:17pm
Northernremedy
HI Ickle,
Body mounting bolt sounds about right, although it's far from substantial. Sheared right off about 5-10mm below the head. I'm very VERY annoyed!
thanks for that, i'll have to get it sorted sooner rather than later but it sounds like a short journey minus rear passengers be ok
Post #381621 24th Dec 2014 5:19pm
