Home > Puma (Tdci) > Hot air from vents
MK
Hot air from vents
Gents
Since a while I“m getting warm air coming from the vents even when the heater temp knob is on full cold (blue). Seems the hot water circuit is not completely shut off. Does it sound like a PIA/front dash remomal? thanks in advance Thumbs Up Puma 110" SW
Post #380434 20th Dec 2014 12:34pm
martinfiattech
Yep mines the same, still very slightly warm. God bless the air con in the summer !!!
If I remember correctly there`s a hot water valve under the bonnet, have a look at him it may not turning off fully. Excuse the spelling I`am better with spanners and wires.
Post #380468 20th Dec 2014 3:48pm
munch90
yes water valve is under bonnet on top of heater fan housing
Post #380469 20th Dec 2014 3:53pm
There is a known issue with 2.4 heaters in lhd vehicles, Land Rover have a fix which involves dash out and a mod to the internal matrix
If I remember correctly forum member dgardel has a copy of the land rover fix procedure
Post #380470 20th Dec 2014 4:01pm
munch90
not sure how a mod to heater matrix could help , as the valve that stops hot water from getting to the heater matrix is under the bonnet
not sure if a lhd is different set up , but guessing it would be much the same just on the other side
Post #380472 20th Dec 2014 4:08pm
ericvv
Here is the heater fix as per Land Rover, but I doubt that it can help for the specific problem here. The heater fix solution is to solve the issue of warmer air blowing thru the vents at the UK driver side, than thru the left side (continental driver side) vents.
Eric
https://www.defender2.net/gallery/albums/u..._fix~0.pdf You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #380489 20th Dec 2014 6:20pm
Cupboard
I'm very glad you posted this, I've just picked a new (to me) Defender up with exactly this problem. It's fine for now, but come summer it's not going to be.
The heater gets hotter as you turn it up, but I spent quite a long time with it on full cold today, where my Hyundai that I drove to pick it up I had to have at about 40% heat.
Post #380503 20th Dec 2014 6:54pm
MK
Embarassed looks a bit time consuming..... thanks guys Puma 110" SW
Post #380544 20th Dec 2014 9:52pm
munch90
If the heaters hot or warm when the control is set to cold then it must be a valve problem or the cable that controls the valve
Post #380591 20th Dec 2014 11:51pm
Eduardo
MK
We are in the same boat. Mine started to fail 2 -3 weeks ago with the same issue.
Should be assesed by my Indy after the hollidays.
Chhers! Eduardo
Post #380613 21st Dec 2014 5:18am
MK
I was thinking to just fit a valve somewhere along the feeding line (Series type of solution) Puma 110" SW
Post #380678 21st Dec 2014 1:42pm
Eduardo
MK
Finally mine was repaired yesterday.
Were not the valve itself was one clip of the control wire that was broken.
Check that first after try to change the valve
Cheers! Eduardo
Post #385149 5th Jan 2015 4:05pm
