Home > Maintenance & Modifications > Wider tyres...
Crafty1980
Wider tyres...
Quick question (sorry if it's been covered elsewhere but the numbers/options confuse me!)
Q: Can you put wider than standard tyres on standard boost alloys? If so, how wide can you go? (...and with/without 30mm spacers?)
Thanks,
Ben
Post #375955 2nd Dec 2014 10:46pm
AndyS
Yes you can, probably 265's will be OK (but wait for someone to verify that).
But why do you want wider tyres, that is the question? Wider tyres will be less efficient at cutting through a soft surface to find solid ground, things like mud or snow. But they'll grip better on tarmac due to the larger contact area. If it's purely cosmetic then do whatever you want. Very Happy
Defenders, for their size, have surprisingly small tyres but I think that is due to the grip on soft surfaces issue. I argued with some chap who wanted wider tyres because he slipped on a load of wet leaves, I said maybe narrower tyres might have worked better and he couldn't see the point I was making. I told him to have a look at rally cars on snow but he still argued wider was better. Oh well.
Post #375957 2nd Dec 2014 10:54pm
mikeh501
265. Spacers make no odds.
Post #375958 2nd Dec 2014 10:54pm
K9F
From another thread.....
blackwolf wrote:
285s on mine. They will work with Boosts although a wider rim is recommended,and unless you fit 30mm spacers (or use wheels with 0 offset) your turning circle will be spectacular! You will also get crud all over the outside of the vehicle (inside too if the windows are open) unless you fit some form of mudflap adaptor. They look great, however!
Popular choices are 235/85, 265/75, both of which cause no issues, or 285/75. Any larger and you'll need suspension mods.
More info on 285s...
http://www.defender2.net/forum/topic8668.html?highlight=285s
http://www.defender2.net/forum/topic3253.html?highlight=285s If you go through life with your head in the sand....all people will see is an ar5e!!
Post #375962 2nd Dec 2014 11:09pm
mikeh501
285's on a 7" rim is pretty dangerous. I wouldn't recommend at all and either would the tyre manufacturer. Its also very likely you will have problems with 285's unless you have a suspension lift (ymmv but that's the norm)
Post #376011 3rd Dec 2014 8:03am
285s are OK albeit not recommended on a 7" rim and you won't have any suspension issues at all.
You will probably need to fit 30mm spacers or wheels with ET0 offset in order to be able to get a reasonable lock, and the outside of the vehicle will get plastered when driving in mud, however.
Post #376016 3rd Dec 2014 9:10am
leeds
Apart from plastering the side of your vehicle with mud, with spacers fitted you will not be able to compete in RTV trials run under MSA regulations. If the tread of your new tyres protrude pass the vertical line dropped from your wheel flare you will need to fit wider wheel flares/ arches to remain legal.
Brendan
Post #376019 3rd Dec 2014 9:35am
285/75 R 16 BFG KM2 Mud T/A on Boosts with 30mm spacers do not protrude beyond the arches and are (subject to being insured of course) wholly legal.
Post #376024 3rd Dec 2014 10:39am
Now from the guys who fit tyres
Yes a 285 will fit a Boost (Many run Zu's on 285's although some say Zu's are 7.5J Confused ) however 285 are not recomended you may find a refusal of fitting at some centres as well
My 50th is on 285 D Modulars on 8J and 0ET whilst the OEMs are being refurb'd Pic's later
Post #376029 3rd Dec 2014 10:55am
Post #376544 5th Dec 2014 10:28am
