Home > Puma (Tdci) > Adapter shaft upgrade |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 123 |
Does anyone know if Ashcrofts are coming up with an adapter shaft upgrade on the TDCi. Pat
12th Nov 2014 9:25am |
Ashcrofts will have an upgrade shaft early next year. Pat
15th Nov 2014 11:51pm |
I think as long as there greased then you got a good chance of them being ok anyway
I think there strong enough its just the lack of lube much the same as the drive flanges , flanges only seem to wear when there dry same as any normal car really if the splines are dry they wear , props do it , drive shafts do it on front wheel drive stuff, even steering shafts do it |
16th Nov 2014 9:28am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
16th Nov 2014 9:31am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
The stealers service foreman here was most reluctant to grease it when they replaced the transfer case. I pleaded and he agreed to but who knows if they did.
AlanH. |
26th Nov 2014 3:21am |
Did he give a reason for not wanting to grease it?
26th Nov 2014 10:24am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6040 |
SO they can sell you another one in 12 months time..... |
26th Nov 2014 12:36pm |
Reason given is that it wasn't a service item...... As an apprentice building gearboxes for road pavers/graders etc I always greased bearings and oiled all shafts and gears etc as a normal part of the assembly process.
Maybe LR can't afford a dob of grease. AlanH. |
26th Nov 2014 11:52pm |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 |
British Airways saved millions a year by removing a single olive from the olive pots... just saying
29th Jul 2020 4:14pm |
