Home > Td5 > Disco transfer box on TD5
Page 2 of 2 <12
grafty99
I would imagine that the power difference (all be it small) helps a fair bit Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #352930 21st Aug 2014 4:47pm
Egoold
What would be a fair price to pay for a disco transfer box on ebay?
Post #354336 29th Aug 2014 8:13am
g-mack
250 ish but if your lucky cheaper. i got one for 80quid last year!!! My 109 thread
my youtube channel
Post #354352 29th Aug 2014 9:55am
^^^ Can beat that.... £25 from a garage on ebay!! Mr. Green
Post #354354 29th Aug 2014 10:05am
There's one complete with difflock on Ebay at the moment for a BIN of £155:-
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...3a8cb01175
If you are prepared to swap the gears over and therefore don't mind buying one without the difflock you may well get one cheaper. Here, for example, is one with three days to go, no reserve, no bids, and a £1 start:-
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...4d22e8391a
Post #354356 29th Aug 2014 10:26am
Anderzander
£21 !
It's an old RRC one mind. Doesn't seen to have many miles on it though.
Post #354360 29th Aug 2014 10:43am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Things to note when doing this.
1. the cruise control won't work, if you have it enabled, but there are ways to fix it.
2. if it's was from an elderly rover, ie Tdi, you will need to swap over the hi/low detect switch housing, if you don't you can make a manual switch in the cab and you can modify the throttle response by activaing that. so that's another option.
3. the prices of these boxes vary, i got mine for about 100 pounds. but some have gotten them cheaper.
4. before you drop the box in, make sure there there's no a lot of play on the front output and rear output, diff lock the box and check, if so, you might have to rebuild the box, the center diff does wear out though.
5. check the oil seals as it's easier to change it when the box is on the floor vs when you are lying down.
on a Td5 with 235/85/16 you will get 120km/h at 2400rpm which is pretty good and a nice speed where the engine is not screaming.
it's a great mod along side a larger intercooler and a remap. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #354556 30th Aug 2014 12:11pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
This is a great mod, I have run this now for 50k and it is the best thing I have done to the 90 along with an auto box.
@achuakh I have wanted to enable cruise control but did not think there was a way to make it work with the Disco tbox, can you let me know how to fix it?
Post #354831 31st Aug 2014 9:34pm
^^^^ You need to use something like this, a generic (usually for motorbikes) speedo adjustment box, which you can alter the output to the dash.
I'd assume you put it in line from the speedo transducer to the ECU (but not the speedo head on the dash, so you still get an accurate reading) to then the ECU won't think the vehicle speed vs. engine revs, is "out of limits" (which is apparently what stops the cruise control from working with a 1.2:1 t/box)
Post #355546 4th Sep 2014 11:05am
achuakh
Yup, one of those such boxes will do the trick to make the CC work by bring it back to within range.
speedohealer is another of those boxes. again, ebay is your good friend and you should be able to find similar products. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #356982 10th Sep 2014 10:16am
drakes
Thanks for that guy this will be a little project for when the hotel quietens down for the winter
Post #357161 11th Sep 2014 7:35am
TD5Nick
United Kingdom 2002 Defender 90 Td5 CSW Java Black
I have had a disco transfer box on my 52 plate 90 for nearly a year and its the best thing I have done, that and a Stage 2 from Alive Tuning. It makes it more drivable and the longer gears help on longer journeys lowering the RPM which seems to help with noise.
Post #360892 28th Sep 2014 9:42pm
Marlin.45
Wales 2007 Defender 90 Td5 SW Baltic Blue
I swapped a transfer box off a 200tdi Disco I was breaking for a .30-30 lever action Winchester which seemed a good deal at the time ( I didn't forsee buying another 90 then) Rolling Eyes Laughing 2006 TD5 90 County
1961 MF35
Post #363210 8th Oct 2014 9:20pm
^^^ At least that has given you another "layer" of security for the Defender! Rolling with laughter
Post #363247 8th Oct 2014 10:35pm
Marlin.45
Soo true Laughing 2006 TD5 90 County
1961 MF35
Post #363610 10th Oct 2014 5:25pm
Page 2 of 2 <12
