Home > Technical > Brake problem.... |
brake pump? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
4th Oct 2014 9:14am |
master or air in the system ?
4th Oct 2014 9:48am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Check your vacuum hoses and vacuum pump and servo.
If everything else is fine and there are no leakages and there is no air in the system might be one of the above. |
4th Oct 2014 11:29am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7722 |
wheel bearings? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
4th Oct 2014 7:41pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
As JST says, or ABS block.
4th Oct 2014 7:45pm |
if new discs were fitted then wheel bearing could be set up to loose allowing disc to push pads away from it , first push of pedal puts pistons back second push gives good pedal and braking effect
4th Oct 2014 8:04pm |
new discs and pads will file spongy tell they bed in
4th Oct 2014 8:12pm |
delab Member Since: 13 Apr 2014 Location: Cornwall Posts: 19 |
Thanks for suggestions to date. I should have said the discs weren't changed. THE LR has just gone throughout the MOT fine so it shouldn't be the bearings although I will check as that suggestion makes sense whereby the first application of brake is spongy then the second application immediately afterwards is really good.
What I can't work out is prior to calliper change the braking was good but now with new calipers it's as I've described... |
5th Oct 2014 12:17pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
to rule out vacuum probs, put foot on brake hard, start engine, you should feel the pedal drop substantially! if it doesn't move you definitely have vac problems. it may move a little, you could still have vac probs! My 109 thread
my youtube channel |
5th Oct 2014 1:05pm |
OK... i've tested the vacuum pump as suggested by g-mack. Pumped the brake several times, start the engine and there's no give whatsoever. So that means the vacuum pump has gone? Do I need to check anything else related to the vacuum pump?
5th Oct 2014 4:00pm |
pipe work from pump to servo ?
not unknown for the servo to crack , have a real good look round the front of it where the master bolts on just out a bit from the flange of the master cyl |
5th Oct 2014 4:05pm |
Thanks for that Munch90... I'll check/ replace that too...
6th Oct 2014 11:06am |
I removed the vacuum pump pipe into the servo and there's loads of suction. The garage inserted some fandangled smoke machine into the servo via the empty hold and state it's not losing compression. Still puzzled then other than maybe the bearings... even though it passed the MOT three weeks ago when I first discovered the 'fault'
6th Oct 2014 5:43pm |
still could be air in the system , just because you cant get any out doesn't mean its not in there
a lot of times the master is blamed , someone thinks its a master problem , changes master , bleeds system all ok , but its the extra bleed that done it not replacing the master when the calipers were done was the system left to drain out , or sealed , change calipers , then bleed to change fluid I would still have a good look at the servo , |
6th Oct 2014 6:47pm |
