Home > Td5 > abs and warning light flickering when under throttle |
Chafed cable under the vehicle. Mine initially only manifested itsel in damp conditions but in the end got worse so I could find it. Intermittant faults are always the worse to find. Took a while but on page 3 I finally located it.
http://www.defender2.net/forum/topic2394.html?highlight=inline If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Sep 2014 2:51pm |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 |
yeah i seen that thread the other day and have checked and the cabling and all looks ok, will have another dig around.
it just seems weird its connected to the acceleration and then backing off, so thats why i though gearbox sensor |
16th Sep 2014 3:27pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Could bearing play cause this? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Sep 2014 10:03pm |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 |
I had same problem and spent months looking, eventually noticed despite all earths being good that there was spiking voltage to ECU !
Earths on battery boxes on both drivers and passengers side of my 90 seemed intermittently faulty, ran a new earth from the battery and through the chassis to both sides. All sorts of issues sorted ! Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
20th Sep 2014 9:41pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1867 |
Loose connection on the abs socket 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
20th Sep 2014 9:46pm |
just an update fixed it finally today
first off replacement handbrake light switch from LR, that sorted the handbrake light working but the lights continued to flicker i then remove the whole handbrake assembly and touched the wire to HB switch straight to the chassis, red light came on wiggled wire no flickering so suspected the the handbrake assembly isn't earthing correctly, so rubbed off some paint on the body beneath the HB and re-fitted went up the road and wiggled handbrake no more flickering Problem solved oh also adjusted HB to 3 clicks now instead of 5 |
2nd Oct 2014 8:33pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1570 |
Try cleaning the White earth header block (plug with loads of wires going into it)beside the pedal boxes and steering column on the bulkhead (left hand side engine bay side near the expansion tank) earths through the stud its fitted to. This controls the instrument warning light earths.
2nd Oct 2014 10:16pm |
