Home > Tdi > Peeved Off |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Be heartened, a clutch master cylinder is very easy to sort out and won't cost the earth.
Just make sure it is properly adjusted once rebuilt or you will have same issues I had |
9th Sep 2014 11:39pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Yeah i am just unsure why son is saying its stuck in reverse but really hoping its just the slave cylinder as was going to do all this when i do the galv chassis up re-build early next year Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
10th Sep 2014 12:23am |
Its just the slave cyl that's gone so i will replace both the master and slave together ordering parts today so hopefully should get it done over the weekend oh and its not stuck in gear either Graham
10th Sep 2014 11:54am |
On the bright side if the weather is crap over the weekend i can now get the 90 into the garage now Graham
10th Sep 2014 11:45pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Master is easy, if a bit time consuming.
Slave is a sod of a job!!! Getting that little plastic clip and the push rod behind it if it comes off is a total grrrrr of a job. Gunsons bleed kit is highly recommended also! http://www.halfords.com/motoring/garage-eq...-eezibleed |
11th Sep 2014 11:10am |
^^ +1
11th Sep 2014 12:46pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
take great care taking the slave of, slowly and gently, it is a mother of a job getting that rod and plastic clip back in. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
11th Sep 2014 12:51pm |
Sorry not been on for a bit ( internet prob's ) but sorted no, anyway sorted my clutch problem i had a couple of weeks ago and replaced both master and slave cylinder's and everything is ok again Graham
23rd Sep 2014 11:37am |
