Home > Maintenance & Modifications > ARB compressor, 1 per axle or 1 for 2 axles? |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
one compressor for two axels. When you buy the compressor it comes with two switches and relays. My Defender and travels
8th Sep 2014 5:05am |
simon119 Member Since: 05 Apr 2012 Location: SG11, Herts Posts: 40 |
They do two types. A bigger one that will do 2 axles and a smaller one that is only really designed for one.
8th Sep 2014 8:40am |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 421 |
The smaller one is designed for working both axles - easily fitted under seat being small - works perfectly only a small amount of air is needed to operate the lockers
The larger one is designed for also inflating tyres and it comes with a quick release air socket |
8th Sep 2014 4:15pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
They do THREE Types.
If its just for your lockers(Front AND Back) you only need the small one. As Boode says only a small amount of air needed and once at pressure you don't need more air, unless you have a leek. Middle size you can inflate your tyres as well and the larger coupled with a tank will be good for much more. |
8th Sep 2014 5:04pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
both axles and air fee spoils and so on it will operate an airline but would take a while 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
8th Sep 2014 5:29pm |
