Home > Maintenance & Modifications > Leaks - under rear windows |
Bearders Member Since: 10 Jan 2013 Location: West Midlands Posts: 9 |
I had exactly the same thing and used silkaflex, it's a marine sealant/bonding compound and can be over painted. I've also used on boats and it's a superb (although it only comes in a few colours so I used black).
One other thing, check the seam between the sides and rear panels above the tub (next to the windows). I did my tub/sides and then found the water was also leaking in there and running along the inside of the tub, appearing at the low point depending how I parked. PITA to track down until I stripped out the inside and used the hose pipe, now been completely dry for almost a year. |
27th Aug 2014 10:57pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1878 |
It is more than Likley coming from the rivets under the window! Yes I know I said rivets my thoughts also.
I bought a rivet gun £10 ish and a pack of blind closed rivets of eBay, and a tube of tiger seal. Drilled out the old rivets, very easy, applied new rivets with tiger seal and no problems since Whole job took me about 1 hour, I was dreading it but actually thoroughly enjoyed it 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
27th Aug 2014 11:26pm |
Raddy Member Since: 20 Aug 2013 Location: St. Sampsons Posts: 55 |
Well that's not ideal!
Think I might have to whip the plastic off and trace where the waters coming from before coming to a conclusion in that case seems it could be one of a few things! Hopefully not the rivets because it's on both sides of the vehicle! We shall see I suppose |
27th Aug 2014 11:37pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
9/10 times it's the foam seal between the side panel and the tub, as said any good quality silicone sealer will do the trick
28th Aug 2014 6:49am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
IF it is the foam seal it's always worth checking the hardtop securing bolts and the little bracket midway along the tub to roof join for tightness. Steve.
28th Aug 2014 12:44pm |
