![]() | Home > Puma (Tdci) > Standard dash type switches to fit in existing holes |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Some are surprisingly expensive...
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
The standard range of switches are available from a main dealer, or Genuine Parts seller, such as Rimmer Bros, Britcar, etc... (in the UK) http://lrcat.com/#30/4/44951 ![]() Click image to enlarge Not shown above - Auxiliary Lights switch YUG000540LNF ![]() There are no 'blank' switches available - but, these can easily be made-up, by using a Heated Seat switch YUF500150LNF - with the 'Heated Seat' front removed and replaced with the front off of the blanking switch AMR5432 The blank front can be modified, with a 2.4mm hole, so that the 'tell-tale' LED can be used, like this - ![]() Click image to enlarge There are also some custom switches available a bit nearer to home for you - http://www.expeditioncentre.com.au/online-...wards.html ![]() ![]() ![]() ![]() ![]() ![]() . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
