Home > Puma (Tdci) > New improved BAS intercooler Fitment help needed |
Marius,
When I fitted my intercooler which may be a different one I believe, I had to open up slightly two of the holes on the intercooler. Only by a millimetre or so, it didn't impact on the security as there were rubber grommets that fitted in the holes. I could get the intercooler to fit but only without the grommets, opening up the holes allowed me to fit with the grommets. Don't know if this is any help but it depends on how far out it is? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Jul 2014 3:09pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 614 |
My local independent fitted mine badly. Afterwards, I got instructions from Allisport and fitted it properly.
Not quite sure how to post links, but it is in my gallery here:https://www.defender2.net/gallery/albums/u...-%20AC.pdf |
26th Jul 2014 4:25pm |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
Im attaching 2 fotos. Hope they show...
My radiator has a k8nd of cut out for the cooler outlet tube. I can get the tube through this but then I cant manure it up any more to fit the pin. Click image to enlarge Click image to enlarge |
26th Jul 2014 4:49pm |
Ok finally got sorted. Had to reduce the length of the right side pin by 2mm.
27th Jul 2014 12:08pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Hi
Sorry ive not seen this post until now, ive been at a the Billing show and had myD3 die on the way home so was a long night You do need to remove the lugs on the radiator to allow the cooler to sit fully flush to it, without doing it they are a fight on the radiator brackets and so do need removing to allow correct fitment of the cooler. Once the lugs are removed I offer the cooler up to the right hand side locating hole first and then to the left last. Thank you Inigo for posting the Allisport pdf. Regards Pete |
28th Jul 2014 9:49pm |
