Home > Puma (Tdci) > 2010 Puma 2.4 PCM/ECU dead short
Ontdekker
South Africa 2010 Defender 110 Puma 2.4 CSW Chawton White
I have had to replace my PCM. It had a dead short within the unit itself, blowing the 15 amp fuse under the seat. I have found no other evidence on the net of this happening. Has anybody else had this problem or heard of it?
What inside the PCM could cause a dead short? I am trying to understand how this could have happened.
Post #347371 24th Jul 2014 12:26pm
K9F
Sounds like water ingress perhaps? Have you been wading? Without a detailed internal diagram it can be difficult to determine. Have you the ability of disconnecting it and checking the connecting cables with an insulation tester to double check it's not the wiring?
If it's already been replaced and all is fine as your post implies unless you send it off to be properly investigated chances are you'll never know or find out. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #347373 24th Jul 2014 12:32pm
Ontdekker
Oil ingress is a TD5 issue? Not in this case, we inspected all the connectors , nothing wrong there.
Post #347374 24th Jul 2014 12:35pm
K9F
Realised that when I posted hence the edit. Sorry. Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #347375 24th Jul 2014 12:36pm
Ontdekker
Apology, I read oil ingress. Water might be slight possibility as I washed it with a pressure washer but I have done this may times previously. Well, new one is in and the fuse is not blowing. These units and the plugs are waterproof?
Post #347376 24th Jul 2014 12:39pm
Caterham
my ECM failed in the early months (mine also 2010) and I understand there may have been a bad batch - I suggest a call to LR may be worth your while.
Post #347381 24th Jul 2014 1:11pm
K9F
Not that waterproof as the wading depth is limited on a Puma and the reasoning I believe behind the extra bulge on the bonnet. Pressure washing is never a good idea around 'sensitive' areas and it sounds like you may have possibly discovered that already?
Big Cry If you go through life with your head in the sand....all people will see is an ar5e!!
Post #347387 24th Jul 2014 1:42pm
marcoegyptos
France
Hi
I got this problem a couple of year ago , it was a bad insulation of the + 24 V wire feeding the ECU and it was touching the air conditioning pipe in the engine compartment . In fact when the pipe was hot , it has burned the insulation of the wire and the fuse under the seat burned.
He took time to found.
May be this can help you.
Post #347416 24th Jul 2014 5:14pm
Caterham
Off Topic
Mal
I stand to be corrected but believe the bulge ie for the ac compressor not the ecm which I think is under the non bulge bit....either way don't think getting water there is going to do it any good.
Post #347420 24th Jul 2014 5:45pm
