Home > Puma (Tdci) > Trainer Indicator Lamp Permanently Illuminated... |
Is the relay adjustable? If not you may need to get an RDX one.
Quick search reveals: http://www.defender2.net/forum/topic29257....iler+light http://www.defender2.net/forum/topic28822....iler+light http://www.defender2.net/forum/topic28343....iler+light If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Jul 2014 12:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19693 |
Get the RDX relay, that will sort your problem.
11th Jul 2014 12:50pm |
Nick Taylor Member Since: 03 May 2012 Location: West Sussex Posts: 18 |
After closer inspection of the supplied relay it I found it had and adjustment screw... so adjusted it until the trailer indicator light now only flashes once when I turn the indicators on... so back to. normal... So now on with the upgrade list...
To do... - k&n air filter - silicon hoses - sports exhaust - Terrafirma shocks and springs - etc.. etc... |
11th Jul 2014 5:54pm |
11th Jul 2014 6:00pm |
Result! If you go through life with your head in the sand....all people will see is an ar5e!!
11th Jul 2014 6:32pm |
