Home > Maintenance & Modifications > 110 van cargo area to cab bulkhead |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Think DIY is your best option,they do come up for sale occasionally as the utilities trucks fit em,but I don't think they are off the shelf products,outa curiousity why a solid cargo barrier? Pov.spec,ftw. 2006, 110,TD5.
16th Jun 2014 8:03pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
Not a genuine supplied item. Fitted by Special Vehicles to vehicles for Utilities.
Companies selling ex- utility vehicles may have one, taken from a vehicle if a purchaser didnt want it |
16th Jun 2014 8:05pm |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 |
Sold mine a while ago.
http://www.defender2.net/forum/topic24845.html |
16th Jun 2014 8:06pm |
Spruce Pirate Member Since: 08 Feb 2013 Location: Stirlingshire Posts: 124 |
If it's a commercial vehicle, depending on what you're carrying (e.g. fuel, chemicals) you should have a solid barrier to prevent hazardous substances entering the cab. A dog guard wouldn't cut it as, in the event of an accident where a liquid container was punctured, it would not prevent the driver and/or passenger from becoming contaminated. Cue discussion on whether the bulkhead would actually prevent liquid entering the cab. Dirty Deeds - Done Dirt Cheap |
16th Jun 2014 8:17pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Thanks folks. I want to be able to make the load area as secure as I can as I sometimes have some expensive kit in there. If the felons can only attack the back door to get to it, that makes it that bit more secure (or it should do once I've finished my back door mods).
16th Jun 2014 8:55pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
A dog guard will give you the correct shaped frame and fixings -
Click image to enlarge which you can then 'panel over' with steel or aluminium sheet, leaving your 'mirror' window. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
17th Jun 2014 12:43pm |
